Halair's F5 build - diyAudio
Old 18th December 2014, 02:32 PM   #1
Halair is offline Halair  Norway
Default Halair's F5 build
Hi People
Long story short, I built myself a pair of fullrange line arrays this spring (my first diy speaker project) and since I know very little about electronics the obvious next step would be to make my own amp
I am curious of class A amplification, the NP F5 is well documented, low part count so seemed to be a good place to start
Currently aquiring the necessary parts and waiting for delivery on most of the little stuff. Transformer is a 400VA/2x18VAC toroid and cabinet is a 4U/400mm unit from Modushop.biz in Italy. Both are in house. PCB bought from DiyAudio Store, transistors from h_a and JFET's from Spencer, rest is pretty much via ebay.
My main intent for this thread is to share my experience and seek information/a little guidance along the way I have read a lot in here including the how-to\s provided by L6L and others and it is sinking in
The speakers intended for this amp is a 20driver full range line array with nom. imp=6.4ohm. Calculated 98dB sensitivity => should work ok?
Old 18th December 2014, 02:36 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
naah .......
sissy speakers .......
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 18th December 2014, 02:56 PM   #3
Vix is offline Vix  Yugoslavia
Vix's Avatar
ZM forgot one word: Fugly
p.s Halair, the Pass amps are all good, it's just about your taste, so don't hurry with F5, there are many other nice Pass amps that will do fine with your "too tall" speakers
Old 18th December 2014, 03:09 PM   #4
Zen Mod's Avatar
naah
no Fugly! without proper porn ( inside , please )
Old 18th December 2014, 07:06 PM   #5
Vix, thanks Fugly? Naaaah....
My impression of my arrays are that they are very articulated yet go surprisingly low, something I hope the F5 can continue to do. I have no idea what to expect but believe in having as little as possible in the signal path present. The arrays have no filters etc, only analoge EQ to counter the top/bottom rolloff inherent to arrays in general.
ZM, thank you too Hope to pick your brain later once the build progress
Old 18th December 2014, 08:06 PM   #6
Array build log here - Halair Column - my line array build (20 FR drivers)
Old 19th December 2014, 03:35 PM   #7
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Halair,
Nice looking speaker. What is the bass response like from this type of speaker? Do you need a sub below 125Hz?
Vince
I build, therefore I am.
Old 19th December 2014, 04:51 PM   #8
A sub from 150hz would be ideal relieving the 3" FR from the most demanding movements, but they hold their own within reasonable SPL Ref attachment.
Old 30th December 2014, 11:26 PM   #9
Have I got this right?
Drawing show layout v1 for physical placement of one channel PSU, I am using 30pcs 2200uF/63V per side, 15 in front of and 15 after R5-8.
I have not correctly drawn rectifier negative to connect with PSU negative rail btw
Toroid will occupy the bottom left side of the layout hence the "heavy" PSU right side.
Old 31st December 2014, 12:15 AM   #10
wow. awsome speakers whats the impedance curv on those suckers?
here is my F5. Dual outputs. +/-24VDC and 2.6A bias.
Halair Column - my line array build (20 FR drivers) Halair Full Range 234 25th December 2014 03:37 PM
How to build the F5 6L6 Pass Labs 1133 23rd January 2014 06:32 PM
F5 Build: How much gain do I need? KevinHeem Pass Labs 15 24th September 2013 11:38 PM
Which F5 to build? Mark Bartley Pass Labs 12 8th March 2013 01:31 AM
F5 build fred0 Pass Labs 31 21st October 2012 10:47 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
