Possible for mix IRF + FQA as complementary mosfet? - diyAudio
Old 18th December 2014, 04:46 AM   #1
pwan is offline pwan  United Kingdom
Default Possible for mix IRF + FQA as complementary mosfet?
Sorry if this sounds a silly question, but I don't think I've seen one done it yet.
Is it possibility to mix IRF and FQA as complementary mosfet ( e.g. IRF for P channel and FQA for N channel, or vice versa) provided similar transconductance? If not, why.
Thanks in advance.
Old 18th December 2014, 05:37 AM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
I didn't think about that and didn't tried
take capacitances in account , too
though , in A class source follower , everything is possible
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 18th December 2014, 09:15 AM   #3
JBL4435 is offline JBL4435  Germany
I'm interested in the same issue.
Attached is a quick comparison of the available (except SFP9610) types that could be used as small signal mosfets.
Do I see it the right way when I say FQP3P20 + FQP3N30 are the best (available) complementary pair?
Old 18th December 2014, 10:44 AM   #4
Zen Mod's Avatar
nothing wrong with IRF 610/9610 , either
Old 18th December 2014, 11:54 AM   #5
The story of P-channel ones from IR made me worried.
Old 18th December 2014, 12:23 PM   #6
Zen Mod's Avatar
well - you didn't said in which apparatus you are planning to use them
Old 18th December 2014, 01:03 PM   #7
The Dastardly Dad of Three
This is a good and interesting thread but also very loaded.
As far as I know, there are no more complementary low power mosfets suitable for audio. Toshiba had the last ones and those are only available as NOS. Prakit on the forums has some available last i checked. So this mix n match approach may be the the only potential solution for production parts But to decide the most important parameters to match ain't always obvious.
I'd go for transconductance as THE most important parameter for a push pull stage.
Last edited by kasey197; 18th December 2014 at 01:05 PM. Reason: Added potential n production parts
Old 18th December 2014, 01:42 PM   #8
F5.
(also, may be other Class AB Hexfet push pull amp.)
In addition what I try to understand is whether or not verticle mosfet P and N channel ( regardless of brands) can be mixed and matched .. based on the gain and Ciss at a particular fixed voltage
Old 18th December 2014, 02:23 PM   #9
Zen Mod's Avatar
yes , they can be mixed
additionally - P3 in F5 is your best friend , if you arm your self with THD analyzer , be it real one , or sound card based + adequate software
Old 18th December 2014, 02:42 PM   #10
Thanks , Zen Mod.
I am now looking on the IRFP240 - P9240 datasheet. Say, at 30V Vgs 4.5V the Id of P240 is ~0.6A while P9240's one is 2A. Very different. I wonder how it actually happening when the working amp..... Solely let the NFB to solve the un-equal gain of both halves?
Complementary V-FET's other than IRF's??? Ultima Thule Parts 36 30th June 2014 08:03 PM
ampli mosfet irf 540 + irf9540 xcicc Solid State 24 20th March 2009 01:10 AM
Replace IRF by Lateral Mosfet lurker Solid State 12 5th January 2006 10:09 AM
Where to buy IRF mosfet in Hong Kong? sianturi Parts 13 17th December 2002 01:46 AM
Mosfet mix on Aleph Ligado Pass Labs 6 16th January 2002 12:43 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
