Value resistor PCB IN/OUT BOSOZ?
Old 22nd January 2004, 09:15 AM   #1
COSMOS is offline COSMOS  Spain
Default Value resistor PCB IN/OUT BOSOZ?
help please, can he tell me that value is the 4 resistances of the BOSOZ PCB IN/OUT signal?, thank you.
Best regards from barcelona
Javi
Old 22nd January 2004, 08:48 PM   #2
hifimaker is offline hifimaker  United States
hifimaker's Avatar
Hi Javi,
It takes a little experimentation, if any are used. Most folks build the circuit as recommended. Try using trim pots where you think you might need or want adjustment. Then remove the trim pots, measure their values, and replace with 1% resisters. Some folks have also placed different input resisters on the input selectors to change the values based upon source system impedance loads. In other words the input resisters are infront of the selector for each source, rather than a single set of resisters behind the selector.
Part of the fun of DIY, we can do stuff like this that commercial products cannot.
Good luck,
-David
Old 23rd January 2004, 01:49 AM   #3
tomchaoda is offline tomchaoda  United States
Default Resistor value?
Cosmos:
Are you asking the value of R15?
Thomas
Old 23rd January 2004, 11:08 AM   #4
Default RE:Are you asking the value of R15?
Hi Thomas!!
I ask for the resistances located in the PCB IN/OUT signals relays, 4 resistances of 1/4W 1% appear I have a picture of this mounted badge but I don't distinguish their value well, but as they have commented me, each person puts the value that considers opportune for that reason I will experience with potentiometers of 500 Ohm there am I will go adjusting until getting a good value but I have the impression that adding resistances of between 100 Ohm and 120Ohm, serious good but any suggestion that you make serious very interesting for my, thank you and forgive for my disastrous English.
Best Regards, Javi.
Value resistor PCB IN/OUT BOSOZ?Hide this!Advertise here!
To BOSOZ or not to BOSOZ... please comment. spence Pass Labs 4 27th February 2012 03:57 AM
Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? promitheus Pass Labs 87 19th February 2006 04:15 PM
screen-plate resistor and grid leak resistor metebalci Tubes / Valves 4 26th February 2004 04:18 AM
X-bosoz vs. CCS X-bosoz, how does the sound compare? acliao Pass Labs 14 26th February 2004 01:55 AM
Resistor values of stepped attenuator for BoSoZ stappvargen Pass Labs 1 21st February 2003 01:29 PM
