Aleph 5 CLC inductor help. - diyAudio
Old 1st December 2014, 07:03 PM   #1
edd9000 is offline edd9000  United Kingdom
edd9000's Avatar
Default Aleph 5 CLC inductor help.
I purchased these chokes to use in the power supply of my Aleph 5 monoblocks build 7448258022 Wurth Electronics | Mouser
I have just realised they are 2x2.2mh, I have 4 of them, but I am not sure how best to use them. Should I just use one per power supply with each rail using half of the choke? Or each rail using the choke in parallel or series to itself.
Thanks.
Old 1st December 2014, 08:18 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
that's nuttin'
good for small current , with substantial DC they're piece of gunk wire
in fact , these are AC line chokes
read datasheet : http://www.mouser.com/ds/2/445/7448258022-71078.pdf
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 1st December 2014, 09:09 PM   #3
edd9000's Avatar
Oops, wrong thing then. Since I bought this project half started I have not done as much research as I normally would do. They were rated at 8amps DC so figured I was looking at the right things.
What am I looking for then? Does it need to be Air core or is Iron core ok, with 1 on each rail what amp rating/wattage should I be looking for.
Old 2nd December 2014, 06:19 AM   #4
Zen Mod's Avatar
air core or hefty iron core
if iron , shoot for more than 2mH , also being sure that choke is declared for at least twice DC Iq
Old 2nd December 2014, 06:46 AM   #5
KatieandDad's Avatar
As Zen MOd has said, yours are for RF interference suppression.
If you look for air cored loudspeaker crossover coils you will be closer to what you actually need.
These are 2.2mH 10A coils.
Old 2nd December 2014, 09:33 AM   #6
Would the Hammond 156B or 159ZL be suitable?
Hammond Mfg. - D.C. Filter Chokes - (153 - 159 Series)
Thanks,
Dennis
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 2nd December 2014, 09:55 AM   #7
Yes, those are designed for DC power supplies.
Old 2nd December 2014, 10:14 AM   #8
Start saving up the transformers from broken microwave ovens.
The EI is easily split since there is no interleaving. Then one can add a thin spacer (0.5mm to 1mm) between the E & I to create a gapped core. Ideal for big chokes with a high DC capability.
regards Andrew T.
Old 2nd December 2014, 10:28 AM   #9
edd9000's Avatar
Thanks for the help. I just got a little ahead of myself.
I will probably just wind my own air core inductor, 14awg should have the power handling needed.
Old 2nd December 2014, 10:49 AM   #10
don't wind it.
Buy a reel of enameled copper wire from SWC (Scientific Wire Company). Their retail division has a new name.
Use the plastic reel as delivered.
regards Andrew T.
F5 CLC inductor recommendation Hikari1 Pass Labs 19 5th February 2014 12:10 AM
Aleph 5 CLC PS question.... john65b Pass Labs 2 24th December 2009 08:59 PM
Double CLC power supply for Aleph 1.2,s daly2k Pass Labs 19 5th August 2006 01:28 AM
Aleph P 1.7 pwr. supply choke clc Shaun Perez 2 Pass Labs 5 9th November 2005 02:17 AM
aleph 5 CLC filter tomchaoda Pass Labs 35 22nd March 2004 04:11 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
