F5 - diyAudio
Old 22nd November 2014, 12:14 AM   #1
Default F5
i had a little current adjustment on my F5. well. a little is from 0.8A to 1A pr Device. and a dual device amp. damn. it will sound more relax
now it is a 2 pair, 1A pr pair 24Vdc amp. alot like the F5turbo v1. offsett stays about 0.01 to 0.1V. temp is easy 45-50C on the sinks. no more. oh. the sinks are 10.080" 6" USA heatsinks. 2 pr side. now its about 2A pr side. the f5 is good with this
now its been a week.
from 1.7A to 2.6A. the amp is a lot more lelaxed. a smoother sound. but the temp did not rise to much
those heatsink USA profiles are very good.
as it it is: 53c and 24c room temp. so. 29c above.
Old 30th November 2014, 02:51 AM   #2
well. i did get to test those USA heatsinks. i have 2 10.080" 6" pr ch. and i i am now running 2.7A at +/-23VDC. thats 124W pr side. and the sinks are below 30c above ambiant at everyting but optimum
so a 250W monoblock is realy NO problem. what so ever.
Old 30th November 2014, 05:07 AM   #3
Halair is offline Halair  Norway
Details please Inquirying mind want to know...
(I am about to start my own F5 once parts start to trickle in...)
Old 30th November 2014, 05:33 AM   #4
PM sent
Old 1st December 2014, 11:13 AM   #5
Intet mottatt
Old 1st December 2014, 07:04 PM   #6
Maybe you will post FFTs showing the distortion spectrum at different bias levels?
Best Regards,
James
Old 2nd December 2014, 11:18 AM   #7
Best Regards,
James
if i only could.
Old 2nd December 2014, 04:44 PM   #8
But its very simple on non bridged amps. You need only:
Fullduplex soundcard on your PC
Download ARTA from artalabs.hr
(You can use this software without registration for free)
Dummy load resistor
The ARTA manual shows how to connect.
Best Regards,
James
Old 3rd December 2014, 08:10 AM   #9
describe your method so that those with the same hardware can implement.
regards Andrew T.
Old 3rd December 2014, 07:14 PM   #10
Default Distortion measurement using ARTA
AudioSan and AndrewT, I know you are one of the most skilled members here. I followed several threads since years and learned a lot from your posts (and sometimes funny discussions).
Having this in mind, I will try to explain:
Hardware:
Compaq 610 Laptop
TERRATEC DMX6FireUSB Soundcard
Software:
Windows 7
ARTA from ARTA Software
Wiring:
For R2 I use a 10k poti. This helps to adjust the input level for the soundcard in order to stay around 0dBFS. The attentuation in dB is not important to know.
For RL (Dummy Load) I use 4.1R/100W Resistor on a heat sink.
And I didnīt use the diodes, but you have to be carefull when testing at high output levels!
A DMM is used to measure the Voltage across the RL. This is needed to know at what level of amp output power the measurement is done.
The best way to learn how to use ARTA for this measurement please refer to the ARTA user manual, section 2, Spectrum analyzer.
This is an example of my F5Turbo_V3 at 2.4A Bias, at 5,66Vrms in 4,1ohm which gives 7,8Wrms:
Please donīt hesitate to ask more detailed questions.
Best Regards, James Watt.
Liquid cooled Aleph-X; F5Turbo_V3 Monoblocks
Operating Vgs and Yfs matched 2SK1530/2SJ201 for the F5, F5 Turbo and F5X NicMac Swap Meet 18 8th December 2014 02:00 AM
Witch amplitude on F5 entrance (calculation check)\ or preamp amplification for F5 erez1012 Pass Labs 2 8th January 2014 07:44 AM
Enhanced F5 / Light Version of F5 Turbo with biasing problem. CLiu Pass Labs 15 26th June 2013 07:16 AM
1M-F5 - A 1 MHz F5 project triode_al Pass Labs 43 25th October 2012 08:28 AM
F5 Cascoded - an alternative for my interest in the Balanced F5 NYCOne Pass Labs 159 24th March 2011 05:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright Đ1999-2015 diyAudio
