adcom gtp 500ll tuner problem,  Nelson Pass maybe?
Old 21st January 2004, 01:25 AM   #1
crippledchicken is offline crippledchicken  United States
crippledchicken's Avatar
Smile adcom gtp 500ll tuner problem, Nelson Pass maybe?
hi, anyone have any idea which component seems to keep going out on these tuners causing them to stop functioning? seems to be a common problem with these units. i bought a service manual on ebay but never received it yet. beginning to look like i might not either. any help would be appreaciated, crippledchicken
Old 21st January 2004, 02:05 AM   #2
jlh28 is offline jlh28
Default funny
not to be rude but.... That is like asking a NASA scientist for help on your model rocket. A little bit of overkill. Sorry, I just thought it was funny.
Old 21st January 2004, 01:22 PM   #3
JCoffey is offline JCoffey  United States
Whats funny is that some "model rockets" are pretty damn complicated, like my 4ft model that will go mach2 and hit 11,000 ft. and built to be able to surive with no damage a fall from that altitude due to failed chute deployment. or the scale models that have gotten up to 30ft tall. Or scratch built solid propellent motors as tall as a man. Or high altitude models that have been able to hit 30k ft+. Not to mention that Mr. Pass seems to be the type of man that will help anyone and everyone he can.
Old 21st January 2004, 04:26 PM   #4
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
Do those rockets have to file a flight plan??
that's high! how do they recover them (100 miles down range?)
....hmmmm google time
Old 21st January 2004, 04:28 PM   #5
Petter is offline Petter
Seems to me it would be much more appropriate to ask someone who works full time on repairs of radio equipment than someone who spends his time designing a completely different class of devices.
Perhaps you can call a local radio repair shop or even the manufacturer if you are looking for statistical data on which components typically fail in a given model.
Petter
Old 21st January 2004, 05:26 PM   #6
ultrachrome is offline ultrachrome  United States
Can you really call a 30' rocket a "scale model?"
Old 21st January 2004, 05:53 PM   #7
Actually yes you do have to get an FAA waver so that they can re-route all air traffic from the area. And you hoof it on foot or atv depending on where your flight field is. Most you normally have to go is a mile or two to get it. There are alot of sofisticated avionics you can install now days that do a staged deployment, where it will seporate at apogee, then free fall until around 800ft or so, then deploy the chute. Allows for alot more precise recovery. Most sport rockets are around 4 to 5 feet tall and only hit around 3 to 5 thousand feet, so recovery isnt too bad....
And I dont guess you could call a 30' tall scale Redstone rocket a model..
www.rocketryonline.com
Old 21st January 2004, 07:54 PM   #8
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Don't look at me, I don't know much about tuners at all.
blissfully ignorant,
Old 21st January 2004, 08:05 PM   #9
Elso Kwak is offline Elso Kwak  Philippines
Banned
Send a message via Yahoo to Elso Kwak
Cool Re: adcom gtp 500ll tuner problem, Nelson Pass maybe?
Hi, Not Knowing anything about rockets but something about tuners..........
First check if all powersupply voltages are present.
Carefully adjust the discriminator coil after marking the original position. If you get sound back, bingo. If not chek if you have IF signal with a scope, if not adjust the frontend with a very weak signal, using a piece of wire as the antenna.
Anyway get a manual and complain at Ebay. Goods not delivered but paid.
Too techno talk? Don't start on it!
Good luck,
ELSO
Old 21st January 2004, 10:37 PM   #10
Thumbs up ah! posting problem fixed thanks for all the decent help
jlh28!not trying to be rude but, i don't quite see what's so funny! NO, i don't own all MARK LEViNSON equipment do you? as far as my question, it was just a very polite question and did not deserve your remarks. before i got disabled, and had to retire, i worked hard for every thing i have. as far as Nelson Pass, he seems like a nice down to earth person, as does john curl, who has helped me a couple of times. and as you saw, mr. pass was nice enough to reply. so why, do you feel you have to insult, and compare my equipment to a model rocket? i have never done that to anyone nor, do i intend to! let me add, i do appreaciate everyone elses help on this subject. thanks, crippledchicken
adcom gtp 500ll tuner problem,  Nelson Pass maybe?Hide this!Advertise here!
Adcom 5800 - Nelson Pass, others CLS2ASTAT Pass Labs 24 21st October 2012 10:21 PM
FS Adcom GTP-600 Preamp/Tuner tomeh! Swap Meet 1 30th April 2011 06:51 PM
Adcom 555II - Nelson Pass ? thylantyr Solid State 53 29th October 2010 08:13 PM
Adcom GFT-1A digital tuner $25 tweakk Swap Meet 5 23rd September 2008 07:27 PM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 01:39 AM
Copyright ©1999-2017 diyAudio
