Quad type bipolar PS for AlephJ - diyAudio
Old 2nd November 2014, 01:13 PM   #1
Default Quad type bipolar PS for AlephJ
ZM suggested that I start a new thread about powering an AlephJ from a 48VDC source using the Quad virtual ground. I have a few questions that I need to ask before I can get started to be sure I understand the circuit and source the correct parts. For reference, I have attached the pertinent part of the circuit. Questions:
1) Why are the initial two resistors not equal? I would have expected 10k/10k. Now if my math is correct, the midpoint sits at 22.7 which is 1.3 below desired and that happens to be exactly double the Vbe of a bjt. I am sure that is not coincidence, but I can't see how it works.
2) The specified bjts are, of course, obsolete. Can they be replaced with a MOSFET pair? i.e. irf240/irf9240. I assume they would need gate stoppers and that plus the difference in Vgs from Vbe would require a different value for the 9.1k R, but I don't know how to calculate it.
3) I would tend to use larger caps, but given the inherent lack of ripple of a battery supply, maybe that is not needed. How about a 0.1uF bypass?
Thanks for your input. I will be ordering all supplies while I am in US and then building everything when I get back to Panama in a few weeks so this may end up being an intermittent for me. Again, thanks for the help.
Old 2nd November 2014, 03:13 PM   #2
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
1. start with equal resistors ; check potential ; alter what's needed
2.use something in T0220 case ; decrease 2K2 value , to bleed more substantial current
3.larger caps , certainly OK ; bypass also OK
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 30th November 2014, 12:13 PM   #3
I thought I posted this previously, but I don't see it, so I'll try again.
That is easy enough to do and I am sure I can end up with good results, but I would like to understand how the circuit works and WHY the two resistors are not equal. Can anyone explain it to me? Trial and error is great (and sometimes the only option), but knowledge is better!
And I assume no heat sink as it is only passing the error current. ?A value like 1k enough? I am not sure what we are aiming for.
Again looking for understanding. A DC battery should have 0 ripple, so the cap is not "filtering." The only other function I know of for a PS cap is to act as a "reservoir." With AB or B this is certainly necessary, but with Class A operation, I thought it drew the same current all the time. Why, then, would we need a "reservoir?" Again, I am not opposed to using them. The caps are relatively cheap and I have several on hand. I just want to understand what they are doing.
Thanks for indulging me. To me, this hobby is part about getting great finished products, but also about understanding how they work.
Old 30th November 2014, 01:11 PM   #4
Zen Mod's Avatar
resistors at bases are voltage dividers ...... and you can take transistors as emiter-followers (buffers) for that voltage level
even simpler - resistors at bases plus transistors are acting as usual bleeders , to help keeping common cap's node at half supply voltage
with 2K2 decrease , current is increased , keeping mid point voltage firmer
even battery supply needs speed ........ and caps are there for that
Old 30th November 2014, 01:20 PM   #5
That much I understood. If they are a voltage divider, why aren't they equal? I am sure it has something to do with the Vgs of the transistors and that using mosfets instead will probably change that, but I do not understand the theory of why they should be different.
Understood. How does one determine how much is enough? 1k. 500, 10???
OK, speed. How does a cap provide speed? And what do we mean by speed? I think of speed as rate of change. If the amplifier will be drawing the same amperage all the time, what is changing? I thought Class A amps ran at a steady state and there was not a change in current with changing input/output. Perhaps that assumption is wrong?
Again, just trying to learn.
Old 30th November 2014, 01:31 PM   #6
Zen Mod's Avatar
Originally Posted by dmtparker View Post
...... To me, this hobby is part about getting great finished products, but also about understanding how they work.
cheers to that!
Old 30th November 2014, 01:38 PM   #7
Zen Mod's Avatar
even your two ears aren't identical , so why expecting N and P counterpart's Vbe needs to be ?
more , the merrier , keeping an eye (brain) on resistor and transistor dissipation
say that 20-50mA is overkill
if you look at Universe as big class A amp , and take it in infinitesimal small moment ..... everything is steady
whatever , if you take several of these moments , you'll see that moving to entropy is slow , but certainly one direction oriented process
so - nothing is steady
though , it helps that caps are faster to give than accu
Old 30th November 2014, 02:19 PM   #8
hm4nine is offline hm4nine  Europe
I have applied this version to get a virtual ground in a previous power amp.
I used TO220 bipolars.
Nevertheless I also connected high wattage (5W) resistors between +/-supplies and virtual gnd - just to feel better for safty reasons....
Results were good - system never failed.
And it's a cheap way to get a quasi monaural supply in a stereo amp with a standard tranny which has 2 secondaries
Old 30th November 2014, 02:33 PM   #9
OK, so no theoretical reason for Rs to be different. In fact, theoretically they should be the same. Difference is just an observed fact that compensates for differences between 2 transistors, correct? I wonder why Quad chose the values they did, however. It would seem that it would need to be a case by case situation if you are just correcting for differences in transistor values.
So 50V/.02A=2500. two R in series (plus 2T) so ~1k each is fine. 50V/2000R=.025A so each R dissipates W=(.025)^2*1000=.625W so 2W resistors needed for safety factor of 3.
Too metaphysical for me. How do caps help 'speed' other than being a reservoir for instantaneous demand? If a Class A amp draws a continuous 100W (for example), other than the ramp up (where an RC network helps avoid in rush current by making it 'slow'), even looking at each 'instant' there is 100W into cap and 100W out of cap. Does it have to do with the 'impedance' of the PS? I have seen this discussed, but don't really understand it.
Old 30th November 2014, 03:41 PM   #10
It' s a must to connect some speed-up caps parallel to a battery. Batteries behave like big and slow caps; they can storage energy - but nothing else. It's similar if you use cheap/high ESR or expensive/low ESR caps in your design.
Personally I go a step further with connecting small caps close to drains/collectors of each power device, not only to improve ESR but also to compensate inductive components of wiring.
Recommendation for premade bipolar PS board? speaker Power Supplies 0 6th June 2014 12:39 PM
Bipolar ps from single ended transformer dmtparker Power Supplies 4 13th September 2013 12:16 PM
FS: Buffalo IIISE DAC, Legato 3.1 I/V Stage, Placid HD & Bipolar PS Modules damohpi Swap Meet 2 30th July 2013 12:07 AM
Bipolar PS plus AC coupled output from opamp? leadbelly Solid State 6 28th July 2009 11:12 AM
Copyright 1999-2017 diyAudio
