The best constant current source for the XA.8 I could get in simulation is the one in the attached file. It also compensates the drain gate current of the MOSFET by delivering this current into the sense resistor. It is temperature compensated by the TL431.
(Of course the 1µOhm resistors are for simualtion only and are replaced by wires.)
It is taken from the pdf-file in
http://www.diyaudio.com/forums/pass-labs/264094-xa-8-single-ended-current-sources-29.html#post4273778
