XA.8 single-ended current sources
Old 29th October 2014, 08:10 PM   #1
MEnsing is offline MEnsing
Default XA.8 single-ended current sources
The XA.8 has a new single-ended current source. See the pictures of the XA30.5 and the XA30.8. On the picture of the XA30.8 I see a Cap and JFET or transistor.
It looks like the resistors have been replaced with a JFET current source, see image 15 of the following link:
https://www.passdiy.com/project/amplifiers/diy-op-amps
I somehow miss the clue how this works. Is there a Pass Labs article that describes the resistors vs JFET current source?
Old 29th October 2014, 09:21 PM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Not really, but you can pretty much get the idea of how a current source
works. A power resistor is a current source of sorts, and we have used
that sort of approach in some earlier products, but we wanted to step up
the amount of single-ended bias used, so in the Xs and .8 products you
will see constant current sources instead, giving more current at higher
impedance.
We have been doing that sort of thing in one form or another since the
Aleph 0 in 1992, and you can read some about it in the article "Leaving
Class A" on the First Watt website.
Old 31st October 2014, 02:02 PM   #3
hm4nine is offline hm4nine  Europe
Besides Nelson's comment I cannot believe to get enough current with a TO92-device to make an effective CCS.
Resistors in their earlier passive CCS were at least 3W-types.
Old 31st October 2014, 02:42 PM   #4
Is there anybody that has the Aleph 0 service manual and that is willing to send it to me? The links to the Aleph 0 documents on this forum don't work anymore.
Old 31st October 2014, 02:43 PM   #5
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
TO92 can govern bigger critter
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 31st October 2014, 02:47 PM   #6
Zen Mod's Avatar
shoot me at >sasica5@gmail.com<
Old 31st October 2014, 02:49 PM   #7
Stefanoo is offline Stefanoo  Italy
Stefanoo's Avatar
100% agree with the comment of hm4nine!!!
Stefano
Old 31st October 2014, 03:10 PM   #8
According to the article 'leaving class A' and my calculations the single ended bias is about 100mA. Should not be a problem for a to-92.
Old 31st October 2014, 04:21 PM   #9
Stefanoo's Avatar
you want to review your calculations
Stefano
Old 31st October 2014, 04:46 PM   #10
If you assume 2x25VDC for supply, you will have 2,5W on a TO92 for 100mA.
You will have SE only a few moments....
XA.8 single-ended current sourcesHide this!Advertise here!
Voltage Sources & Current Sources rascal101 Everything Else 3 13th September 2012 12:56 PM
Looking for single ended DAC with current output. oon_the_kid Digital Line Level 4 13th June 2011 02:28 AM
How do I connect a current output DAC to I/V stage single ended Thermosphere Digital Line Level 10 25th September 2010 07:41 AM
How does the current source work in a single-ended amp ? tessier Pass Labs 1 4th September 2010 08:39 AM
Single Ended, Single driver: In-room distortion measurements Gerrit Boers Full Range 4 27th November 2007 08:12 AM
