power factor correction in class a amps - diyAudio
Old 24th October 2014, 04:09 PM   #1
daly2k is offline daly2k  United States
Default power factor correction in class a amps
Next to trying to figure out dark matter and dark energy's affect on the universe the next pressing question for me is -- will power factor correction work on Class A amps to make them more efficient (green) and suck less power from the AC wall sockets? I read an interesting article in audio express about an amp manufacturer actually using it in his amp (switching power supply) and it got me thinking.
We all know that are speakers are reactive loads on the amps output and it would seem that this science would work on a linear amp. Has anyone ever tried these circuits on a Pass project? I know that most of us are happy to reduce ripple with voltage regulators so this would be more a project to gain efficiency and reduce heat. Any ideas anyone?
Old 24th October 2014, 06:16 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
naah ........ that matter is just too dark
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 25th October 2014, 11:53 AM   #3
The amplifier uses power.
The connection between the mains and the amplifier will not be 100% efficient.
Different topologies will have different losses/efficiencies.
Capacitor input filters, whether into an SMPS or a transformer fed rectifier/capacitor are both terrible for creating distortion of the mains waveform.
Some SMPS have circuitry for reducing this distortion effect.
Many SMPS, especially the lower power types, have no distortion reducing circuitry.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 25th October 2014, 12:24 PM   #4
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Bothered to estimate what the gain will be ? In power, not lb.
(A crane and my 7.5' x 7.5' hot tub arrive tomorrow, 1000+ lbs. Just found out it requires more than 2 circuit breaker/groups, 16A/230Vac, to cook a white man)
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 25th October 2014, 02:03 PM   #5
Another green option to try is be able to reduce plate voltage and cathode current when you do not need full power. I typically reduce both by 20% when I do not need it. Power required can be cut in half.
Old 25th October 2014, 05:37 PM   #6
The one and only
Nelson Pass's Avatar
Power factor is more a matter of losses in the AC line and transformer
windings, and correction will improve that, but I don't expect that it will
much affect the audio performance.
Many SMPS manufacturers are also including power factor correction in their
products as it is becoming a requirement in various countries and classes of
products.
As an indicator of how much energy we are talking about, power factor on
things like Pass Labs and First Watt amplifiers is about 80%.
Old 25th October 2014, 05:54 PM   #7
Do you mean something like speaker impedance equalizing?
Old 25th October 2014, 08:36 PM   #8
No equalizing-just an idea based on an Audio Express article. During my professional years I was responsible for designing and building Pharm and chem plants. Of course all the mains transformers had three phase PF correction but this was the first time I had seen it used on an Audio amp. I understood that it would not make an audio improvement but would lessen the electric consumption. Not a problem for me just an idea. dave
Old 25th October 2014, 09:46 PM   #9
Destroyer OS's Avatar
PFC networks can be used to attenuate some noise. The Uberbuss uses one. The details are not available, and I don't know how much attenuation.
Are you just looking to improve noise in the class A? I need to get to work on my dual rail PSU board...
What's the amperage used by all these Pass DIY projects? (The range, v is like 12-40 right?)
Old 25th October 2014, 10:04 PM   #10
jcx is offline jcx  United States
rectifier-capacitor input supplies draw current in large pulses for few milliseconds at the peaks of the line V waveform - the pulse current peaks are very much larger than the average or rms current
PFC circuits use switched inductors up front to give near continuous, proportional to line V current - like a pure resistive load
if the high frequency switching transients are well controlled with careful EMI design then the PFC smoothed line current draw means the PFC equipped devices "play nice" with every thing else plugged in nearby
since most EMI measures work reciprocally good PFC supplies will also have better immunity to external EMI sources
Power factor correction for audio? eem2am Power Supplies 8 5th July 2011 12:49 PM
Power factor correction circuits gearheaddruid Power Supplies 27 17th March 2010 11:12 AM
Power factor correction Stefano Pass Labs 3 12th July 2008 01:58 PM
Power Factor correction daly41k Pass Labs 4 30th June 2007 11:28 PM
Power Factor Correction Narcisse91 Power Supplies 16 30th September 2006 04:04 PM
Copyright ©1999-2017 diyAudio
