Re: Amps Built?
The case has changed a few times, but I think I have the concept I want now. Ironicly it's what I was going to do more than a year ago with BrianGT's boards. I finally got the smaller caps together to fit the board. It will be BG's in the signal path and your Nichicons elsewhere. Now I have to reconcile my 35V rails with the correct resistor values (Your part numbers with that of the Pass Aleph 5). I'm going to try to move the trimmer to the R19 position. I've been thinking about implementing the HHCCS for the diff-input current source. I also have to figure how to use my Caddocks for the output resistors.MikeW said:How are the amps coming? I have one extra mini-A if someone would like to try it for a while.
- Mini-2
