I want to make an Aleph 5. I'm completely new in DIY world so I will probably post a lot of questions here. For starters I have a question about the components that should be used in the amplifier. I saw Mr. Nelson used Dale resistors, and now I would like to know good and bad points of using better resistors (RIKEN). One Dale resistor is $0.40 and Riken is $2.40. Same thing for capacitors. What do I get if I use Black Gate electrolits (220uF)? Or maybe something different. Please tell me your opinion. Let's say I'm not limited with finances and I want the best out of Aleph 5 design. All suggestions are welcome! |
#2 |
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#3 |
diyAudio Moderator Emeritus
If you do a search on the forum, you'll find a number of threads that will discuss the pros and cons of most of the different components that go into the Alephs and other amps.
Rodd Yamashita |
#5 |
the good thing about the Aleph circuits is that you don't need to
build them with exotic parts for them to sound great! (at least that's my opinion) |
#6 | |
This goes for any of the passdiy constructions....actually a part of the beauty of them Magura
#7 |
I'm not an expert, but from what I understood (by reading here and there) the most gain comes from a good power supply and being able to increase the bias a bit (requires good cooling).
I myself did use some above average components as well (caddock power resistores, vishay/dale resistors, big tritec coils, BG caps, BCC elcos, beefy toroid, Kimber wiring and plenty of WBT eye candy), however this makes it a lot more expensive. Still don't know if it really matters much.
Is that all there is? |
#8 | |
Probably doesn't, but it shure feels/looks good and makes us sleep well at night
Mads K |
#9 | |
I tought so. I think I got a picture now. I'll just use some mid priced elements. Thanks everyobody for comments. |
#10 | |
But I always use a bottle of Cabernet for that
| Internal wiring | ceebmoj | Chip Amps | 8 | 23rd January 2008 10:01 PM |
| Which cable to use on Aleph internal wiring? | Sony | Pass Labs | 4 | 25th May 2005 02:05 AM |
| Internal wiring | Scribble | Chip Amps | 1 | 4th November 2004 05:52 AM |
| Aleph internal wiring choices? | dantwomey | Pass Labs | 13 | 18th April 2003 05:54 PM |
| Internal wiring | 2Bak | Parts | 5 | 29th July 2002 09:37 PM |
| Page generated in 0.11403 seconds (76.18% PHP - 23.82% MySQL) with 10 queries |
