SIT Power Follower revisited - diyAudio
Old 19th September 2014, 08:53 PM   #1
Default SIT Power Follower revisited
Attached pics. are of the latest incarnation of my 2SK82 power follower design. I have come to the conclusion that the design benefits from a higher B+ and corresponding higher dissipation - approx. 100w per channel. Rather than stick everything in a 5U case I decided to design a more compact fan-cooled chassis. The 12v computer power supply fan is powered from an external wall-wart supply, relay switched from the amp.
Because of my chosen configuration I had to use a cased transformer to direct the airstream to either side where it comes into contact with the SITs. Part of the flow then exits via 'bleed' holes in the heatsink and the rest of the airflow hugs the inside of the heatsink to exit via the slots at the top.
As far as I can measure I have been able to achieve 0.2deg.C/W and the heatsinks are comfortably warm dissipating the combined 200w. The 1/4 inch front and 1/8 inch thick rear faceplates also contribute to the heat dissipation surface area.
I am now a convert to fan-cooling and its benefits in allowing the design of more compact enclosures when there is a need to dissipate serious amounts of class A heat.
Old 19th September 2014, 09:31 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
me likee
great workmanship
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 19th September 2014, 09:40 PM   #3
soundhappy's Avatar
Interesting 2SK82 amplifier congratulations
I like a lot big filtering caps , nice build amp !
What is output class A power ?
Schematics be always welcome.
All is perfect is a ready finished version?
What about vfet sound subjective descryption ?
Have a nice day
Best regards
class A amplifiers with full range speakers sings
like angels in heaven
Old 20th September 2014, 03:25 AM   #4
The one and only
Nelson Pass's Avatar
Really nice...
Old 20th September 2014, 06:33 AM   #5
juanitox's Avatar
100W on a 95W max device ?! i probably missed something
French is not a crime.
Old 20th September 2014, 08:44 AM   #6
Zen Mod's Avatar
ya see these golden resistors ?
Old 20th September 2014, 12:07 PM   #7
juanitox's Avatar
probably heat fuse
Old 20th September 2014, 01:20 PM   #8
I really hope not, but I strongly suspect that a large part of my motivation in posting is a shameless angling for approbation from the more exalted members of this forum - thank you Zen Mod and Mr. Pass .
Soundhappy - Refer to the thread ' SIT Variations ' for the original schematic. The current design is just a higher voltage version with corresponding higher dissipation. The theoretical output of the design is about 10 watts but realistically, usable output is 5 to 7 watts and that is going downhill with a strong tailwind !
As to sound quality - Few of my DIY attempts make it pass the bread-board stage. Fewer still possess sonic qualities meriting further refinement. That this source follower design is in its 'mark 2' version says something of my regard for its sonic qualities. I am however, not ready to give up on tubes and I am just about to embark on building what I consider to be the ultimate expression of single-ended amplifier design and that is tube based.
Old 20th September 2014, 08:12 PM   #9
soundhappy's Avatar
Yes i find it !
SIT Variations
Thanks for your answer
Greetings
Old 21st September 2014, 05:14 AM   #10
n3szd is offline n3szd  United States
n3szd's Avatar
Nice, they make some nice enclosures from our sponsors, we make heat sinks at work, any kind you can imagine
we need the work, BTW nice unit, a labor of love...
Rob
Ultrasimple SIT PP amp from BAF , or SIT Beast with a Thousand PSUs Zen Mod Pass Labs 337 24th March 2014 02:22 PM
Should I let unused amps sit or power them up and use them on occasion. bugman53 Solid State 6 22nd November 2012 09:59 AM
SIT-1 and SIT-2 owner manuals Nelson Pass Pass Labs 25 12th September 2012 07:16 PM
SIT power jfet yero Pass Labs 22 14th April 2012 02:14 AM
SIT Power Amplifier??? mad_z Solid State 8 26th January 2009 08:31 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
