Front Panel Designer files + photo's of your projects
Old 10th September 2014, 03:04 PM   #1
albertNL is offline albertNL
Default Front Panel Designer files + photo's of your projects
Designing a front or rear panel can be a pain and it is great to learn from others. I have spent many hours looking at photo's of commercial and DIY amps before deciding what the rear panel of my Aleph-J should look like. I know, it's only a rear panel that not many people will every see, but I wanted to do it right.
I hope others can be inspired and will add more files to this thread.
To avoid cluttering up the thread please let's not make this a discussion thread. I would like it to become a repository of great ideas and examples.
Keep it simple. Upload FPD files, photos and descriptions. I look forward to seeing some great projects.
Thanks,
Albert
Old 10th September 2014, 03:12 PM   #2
Default Aleph-J rear panel
FPD file and photo of my Aleph-J rear panel.
The case is from modushop, a 4U 400mm Dissipante.
File Type: jpg Aleph J rear panel diyaudio upload - kopie.jpg (160.5 KB, 270 views)
File Type: zip Rear panel AJ.zip (832 Bytes, 26 views)
Old 10th September 2014, 03:22 PM   #3
TheShaman is offline TheShaman  Europe
Thanks Albert.
This can turn into a very useful (and time-saving!) thread.
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 10th September 2014, 03:28 PM   #4
Please do not hijack this thread within minutes of its creation.
This thread is for people who would like to learn by seeing what others have done using FPD.
Old 10th September 2014, 03:30 PM   #5
komigenie is offline komigenie  United States
komigenie's Avatar
No problem
I started to modify them trying to get a better sound out of them. Then it became a hobby, then it became an obsession.
J.J. Cale
Old 10th September 2014, 03:34 PM   #6
komigenie's Avatar
Just to let you know, NO ONE can use your design with different connectors right ? That was the point ... @ last post description with design and FPD files what connectors are used, and link to place where to get them ... This should be useful ...
J.J. Cale
Old 10th September 2014, 03:57 PM   #7
In order to keep this thread as clean as possible, I have opened a new discussion thread at:
http://www.diyaudio.com/forums/pass-labs/261781-front-panel-designer-files-photos-your-projects-discussion.html
Thanks,
Albert
Front Panel Designer files + photo's of your projectsHide this!Advertise here!
Front Panel Express Files MrMajestic Construction Tips 20 3rd April 2013 06:15 PM
Quality aluminum anodized front panel for your DIY projects Praudio Swap Meet 0 25th March 2013 04:39 AM
(new internal photo added)AcF's new tube amp projects Maniac Acoustic Fun 2 17th January 2011 10:39 PM
Looking for a photo of the front of the Selenium 15" Coax Cal Weldon Multi-Way 8 1st February 2005 11:51 PM
Any panel speaker projects? SsZERO Multi-Way 1 16th September 2002 07:13 PM
Copyright ©1999-2017 diyAudio
