F5c (cascode) cviller boards 40 V rails build - Page 2 - diyAudio
Old 19th August 2014, 09:51 PM   #11
I soldered MOSFETs to the boards, planning to suspend the boards by the MOSFETs horizontally. Though the heat sinks are drilled to mount the boards to the sinks using spacers, I prefered horizontal placement simply for the ease of adjusting bias with P1 and P2 with the top of the chassis off. Take a look at the 3rd and 4th photos, in which I had loosely mounted the MOSFETs to the sinks to see what it would look like. I am sure that most all of you immediately see the problem that was not obvious to me.
(Christian - great to hear from you. I have received great feedback on your boards, and as you can see, I am finally getting around to using them, myself.)
Old 19th August 2014, 10:25 PM   #12
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally Posted by toxic ingestion View Post
I soldered MOSFETs to the boards, planning to suspend the boards by the MOSFETs horizontally.........
nono
you must suspend pcbs separately
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 20th August 2014, 12:00 AM   #13
Originally Posted by Zen Mod View Post
nono
And why is that, ZM?
(There is yet another problem in this horizontal suspension.)
Old 20th August 2014, 01:59 AM   #14
Zen Mod's Avatar
when you add wires , combined physical load and thermal cycling will cause boom
big badaboom
ZM , AKA LeelooDallasMultiPass
Old 20th August 2014, 02:00 AM   #15
Zen Mod's Avatar
be creative - support these pcbs
Old 20th August 2014, 03:23 AM   #16
a.wayne is offline a.wayne  United States
Sin Bin
will cause boom
big badaboom
Old 20th August 2014, 04:36 AM   #17
Thanks for the insight regarding suspending boards that can get both heavy and hot. Having one of those droop down and shorting out on the sink or elsewhere would not be desirable. I have attached a photo of a previous build where I used horizontally mounted boards but suspended them from below, as they should be in that situation.
As I said at the beginning, I make new errors and learn new things with each build. In addition to ZMs important point about how wrong it is to suspend a board from MOSFETs by themselves, the other problem I had not anticipated was that when sitting horizontally, the boards hit the transformers and PS caps, preventing the chassis from fitting together (pictures below). This would not have been an issue with a single transformer and single PS board, but certainly was with dual mono construction.
Lesson learned. 6L6 prodded me to simply mount them as designed, which is what I should have done to begin with. MOSFET leads were clipped close to the boards. After using copper braid to clean up the boards (about 20 minutes), I could easily use these same MOSFETs with the boards mounted correctly on the heat sink with aluminum spacers. The last photo shows the board and MOSFETs loosely secured to the sink prior to soldering them into place.
Old 20th August 2014, 07:49 AM   #18
cviller is offline cviller  Canada
cviller's Avatar
I actually find it easer to do the adjustments with the boards mounted to the sturdy sinks as you have now done.
To make it easier to reach the posts and optimise the mosfet placement on the sink, I normally mount them upside down (with mosfets in the bottom).
Old 20th August 2014, 01:41 PM   #19
Hi. I don't understand exactly what you mean by your statement that you mount "them upside down (with mosfets in the bottom)." Might you explain a bit or provide a quick photo or sketch?
Thanks.
Old 20th August 2014, 02:00 PM   #20
Zen Mod's Avatar
mosfets at lower half of heatsink , pcb upwards
locate mosfets at approx. 1/3 of heatsink height
Cviller's F5c thor61 The diyAudio Store 16 2nd June 2014 06:18 PM
Cviller's F5c thor61 Pass Labs 17 22nd March 2014 02:37 PM
F5c V2.0 Cascode Build Documentation toxic ingestion Pass Labs 88 18th March 2014 02:08 PM
F5c V2.0 cascode PCBs by cviller - buy or trade? toxic ingestion Parts 0 17th June 2013 04:12 AM
FS:One pair, F5 cascode boards by cviller hags Swap Meet 1 1st March 2012 08:32 PM
Copyright 1999-2017 diyAudio
