LC Audio story on current woppling?
Old 5th May 2005, 12:34 PM   #141
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Of course small caps are less costly than large ones. What I meant is that 5 x 1000 uF 50 V are more expensive than 1 x 4700 uF 50 V for instance.
I hope the link works:
http://nl.farnell.com/jsp/endecaSear...&No=25#results
At Farnell a 1000 uF 25 V Panasonic FC costs 82 eurocents, a 2200 uF 25 V Panasonic FC costs € 1.27. What is cheaper when the same capacity is required ?
It's only audio. Member of the non modular PCB design committee
Old 5th May 2005, 02:35 PM   #142
LBHajdu is offline LBHajdu  United States
Over here if I buy 4x15,000uF@50v Panasonic in big cans, and I buy 60x1,00uF@50v Panasonic in small cans. The small cans are less costly. This is mostly attributed to the large volume discount on the 60 caps with is almost 75% @ (200caps) , if I remember correctly.
Leve
Old 5th May 2005, 04:58 PM   #143
Lars Clausen is offline Lars Clausen  Denmark
If you can't use one big cap, better to use 25 small ones, than 2, 3 or 4 semi big ones. Why? Because the smaller ones have a large internal resistance compared with the combined low resistance.
A 100 uF may very well have 1-2 Ohms, when you put 25 in parallel, the total resistance is down to 0.04 Ohms which is ok for a 2500 uF cap. This way current woppling is kept down. (If it exists )
Anyway still better to pay the extra 25c and get one big cap
www.newclassd.com
Old 6th May 2005, 02:55 PM   #144
I sometimes get very frustrated with this forum. I’m always getting contradictory advice, power supplies seem to be a particularly divisive topic.
So your recommendation is that one big cap will sound best. It has however been stated before the big caps charge / discharge very slowly (why is this) . Wouldn’t this effect be more detrimental to the sound?
For the same money I can get a lot more uF in small cans, does that play any roll in the decision?
LC Audio story on current woppling?Hide this!Advertise here!
JL AUDIO 250/1 idle current Pioneer621 Car Audio 2 24th April 2008 10:31 PM
