The diyAudio build guides
Old 17th July 2017, 12:42 PM   #81
Marra is online now Marra  United Kingdom
Originally Posted by Variac View Post
They ARE ultra awesome! And I'm sure have allowed many people who ordinarily couldn't have built amps successfully, succeed! A great contribution to our community!
I could not agree more.
Old 14th October 2017, 11:23 PM   #82
paugie is offline paugie  Philippines
Good morning
I am an old (63YO) audio enthusiast with very little soldering skills (acquiring some).
My sound system consists of Class D amps (Samwu TPA3118, Weiner, and lately a 3255EVM which I swap on whim outputing to a pair of Tannoy bookshelves.
My sources are a TV, DVD player and a Digital Box which plays FLAC, WAV and MP3s
For volume control, I route the input signal to a cheap 2-tube buffer. I was able to buy an external switch to select sources but it is flakey.
I would like to assemble a pre-amp with minimum work, hopefully forgiving in the soldering area. And if possible the minimum number of components and cost.
Would anyone please advise me whether the Bi or the Mesmerize (or other circuti) would fit my requirements.
I have very little info about these circuits except that they have a selectable input and very good reputation for sound output.
Thank you.
Old 15th October 2017, 01:01 AM   #83
KevinHeem is offline KevinHeem  United States
KevinHeem's Avatar
The B1 would work for you. Boards and Jfets are available at PassDiy. It's not a complicated build, you can easily handle it.
Unless the fact that the B1 board from Pass only has two switchable inputs creates a problem for you.
Old 15th October 2017, 05:32 AM   #84
Thank you, KevinHeem
I will look into it.
I suppose the number of inputs can be changed.
Old 15th October 2017, 08:02 AM   #85
I'm sorry, I forgot to mention.
I also use a turntable through a discrete phono preamp before the tube buffer.
Will that be a complication?
Old 15th October 2017, 08:45 AM   #86
R.I.P.
The B1 feeds the power amplifier.
For phono you use:
phono > RIAA pre-amp > B1 > power amp
or
phono > RIAA pre-amp > tube buffer > B1 > power amp
You would need the tube buffer only if your RIAA pre-amp cannot adequately drive the cables to the next stage.
The B1 accepts two inputs, whereas the DCB1 based Mezmerise has upto six inputs.
regards Andrew T.
The diyAudio build guidesHide this!Advertise here!
diyAudio Power Supply Circuit Board v3 illustrated build guide 6L6 Power Supplies 680 10th June 2018 04:26 PM
diyAudio F5 Build Guide Jason The diyAudio Store 32 2nd May 2018 06:00 PM
DIYAudio SoftStart Build mattmcl Solid State 9 27th February 2013 08:35 PM
Aleph 30 build by diyaudio newbie NiklasJ Pass Labs 8 7th February 2012 11:11 AM
New to DIYAudio Help With New Build? buzz1167 Solid State 58 16th August 2010 02:41 AM
