Threshold NS-10 and M1 info. wanted Threshold NS-10 and M1 info. wanted - Page 9 - diyAudio
Old 24th February 2006, 09:13 AM   #81
beppe61 is offline beppe61  Italy
Originally posted by Malotron
Here's a shot of a M1 module if anyone was curious...
Dear Sir,
I am very curious about this M1 "active impedance matching module".
Could you tell me anything about its schematic ?
Is it a buffer?
Maybe with a nice pot in front of it could be an even more basic line stage.
Thank you so much.
Kind regards,
beppe
Old 24th February 2006, 06:31 PM   #82
Malotron is offline Malotron  United States
Malotron's Avatar
Hello Beppe,
I'm afraid my knowledge of electronics is limited and the manuals for my Threshold equipment was lost in a flooded garage in 1997. What I can tell you is how the module works with the NS10. The M1 is for matching the impedance of various ( 900 to 1.5 ohms ) moving coil phono cartridges so, in my case, my Dynavector 23R plugs into the 1.5 -10 ohm input and out to the one of the NS10's magnetic cartridge inputs. It has one modification: I replaced the 6 47uF tantalum caps with Panasonic FCs. How does it sound? Real nice with quality vinyl, like say, "Art Pepper Meets the Rhythm Section,": solid, wide imaging through 15 ohm Rodgers Ls3/5a's and tight extended bass through custom Kef SP-200 EBS subs. So, yes, for impedance matching MC phono cartridges the M1 through the NS10 is great. I couldn't say for other applications.
Thank you Nelson Pass.
-Mal
Old 25th February 2006, 05:22 PM   #83
Hello Beppe,
-Mal
Dear Sir,
thank you sincerely for your kind and very valuable reply.
Kind regards,
beppe
Old 26th February 2006, 12:52 AM   #84
apassgear is offline apassgear  Mexico
apassgear's Avatar
Beppe
Check Nelson's list for Threshold SL10, you will find what your looking for on that schematic sheet.
http://www.passlabs.com/np
Old 26th February 2006, 09:20 AM   #85
Originally posted by apassgear
Beppe
Thank you very much for the link,Sir.
Kind regards,
beppe
Old 2nd May 2006, 04:47 PM   #86
Tyimo is offline Tyimo  Hungary
Default NS10 specs
Hi!
Could somebody tell me the specs of the NS10?
How much gain has it? How many output voltage, impedance etc.?
Is it as strong as the BOZ?
Greets:
Tyimo
Old 2nd May 2006, 05:24 PM   #87
yeoldestereo is offline yeoldestereo  United States
See Pic below for specs
Old 2nd May 2006, 06:41 PM   #88
Thanks!!
Old 20th May 2008, 07:59 PM   #89
RobertS61 is offline RobertS61  Netherlands
Default Levinson JC-2
From YeoldeStereo
The picture on the post is of the SL 10 which has an outboard power supply. Of which most other high end manufacturers later on copied. I think the SL 10 was the first high end preamp to use an outboard power supply. Although I cannot be a 100 percent on that statement.
The Levinson JC-2 had a outboard powersupply in 1974 with the line cords vast attached to them. Later in 1975 I believe they used a PLS-150 Powersupply for it.
Can buy a NS10 pre for my second system to replace a Yamaha C2-a but I'm not sure because of the age of at least 30 years.
Greetings
Threshold NS-10 and M1 info. wantedHide this!Advertise here!
Threshold PCX Crossover Info wanted.. Daveis Pass Labs 18 18th December 2015 12:21 AM
Threshold FET 9 cartidge loading DIP switch - info please? laugoo Pass Labs 1 19th December 2008 06:35 PM
Threshold FET-1 Mk2 Pre Info michelc.1953 Pass Labs 3 21st August 2008 06:54 PM
Threshold S/550e Info EchoWars Solid State 7 9th July 2006 06:03 AM
B&W DM7 info wanted Jerry T. Multi-Way 2 26th January 2005 04:59 PM
Copyright ©1999-2017 diyAudio
