Rising DC Offset
Rising DC Offset
Old 31st July 2014, 02:28 PM   #11
pmchoong is offline pmchoong  Malaysia
pmchoong's Avatar
Originally Posted by uli View Post
running this without a load is the way to go. even offset near the rail voltage should not harm
you mean remove the mosfets?
Old 31st July 2014, 02:36 PM   #12
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Rising DC Offset
he meant nothing attached to amp's output
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 31st July 2014, 02:36 PM   #13
Zen Mod's Avatar
Rising DC Offset
Originally Posted by pmchoong View Post
I have replaced all Q2, Q3 and Q4. They are new. The only different is thatthay are BC550.
took care of pinout difference ?
Old 31st July 2014, 02:37 PM   #14
uli is offline uli  Austria
no, they are integrated part of the circuit. Load would be a Speaker. start measuring the voltages across the resistors like R7, R8, Z1, Q3 E-C, Q4 E-C.
then compare to the working channel. maybe only the value of R7 Needs to be changed a little bit or the value of Z1 is slightly out of spec.
does the offset run to - or + supply?
having too less voltage across R7 means positive offset and the way round
'Jazz is not dead, it just smells funny' F.Zappa
Old 31st July 2014, 02:38 PM   #15
biju55 is offline biju55  India
biju55's Avatar
Re-solder the 2sj 109 and its related components . Clean well the space between the legs of sj109 .
Old 31st July 2014, 02:47 PM   #16
pmchoong's Avatar
Voltage across R7 is 5.10V in the 2 seconds that I measured it.
Old 31st July 2014, 02:49 PM   #17
let the amplifier warm up! it makes no sense to Switch off after 2 seconds. again, does the Offset drift towards - or +?
Old 31st July 2014, 03:04 PM   #18
pmchoong's Avatar
It drifts towards the +.
If i let the offset to climb, it will trigger the speaker protection board.
Old 31st July 2014, 03:09 PM   #19
put away the speaker protection when bugtracking :-)
Old 31st July 2014, 03:12 PM   #20
pmchoong's Avatar
wouldn't it burn the mosfets?
Rising DC OffsetHide this!Advertise here!
What is DC offset? spooney Car Audio 16 9th September 2013 12:32 AM
Dc offset Vrystaat Solid State 9 14th May 2013 06:16 PM
DH-220 Clone (SMART TA-242) can't adjust DC offset using offset bias pot? beady Solid State 6 17th March 2011 10:53 AM
DC Offset JannaCassandra Chip Amps 3 26th July 2008 03:20 PM
Rising DC voltage DragonMaster Power Supplies 4 24th April 2008 03:55 PM
