Rising DC Offset
Rising DC Offset
Old 25th August 2014, 03:49 PM   #91
pmchoong is online now pmchoong  Malaysia
pmchoong's Avatar
Thanks ZM. With the output connected to ground measurement, please see attached drawing.
Old 25th August 2014, 04:28 PM   #92
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Rising DC Offset
it seems everything is ok
remove bridge from output to gnd , put one pair of (checked!) mosfets in place and power it up
report here
when you have functional amp with one pair , you'll put second one
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 26th August 2014, 03:13 AM   #93
pmchoong's Avatar
Thanks ZM. Should I disconnect the input from the ground as well? I also noticed that the board vibrates when it's powered up and the transformer buzzes.
Old 26th August 2014, 09:46 AM   #94
Zen Mod's Avatar
Rising DC Offset
Originally Posted by pmchoong View Post
Thanks ZM. Should I disconnect the input from the ground as well?.......
all the time - until it's ready to sing
T...... I also noticed that the board vibrates when it's powered up and the transformer buzzes.
with or without mosfets in circuit ?
even if I can't see anything wrong on your pictures , you're th eone who need to check every connection
insert Ampermeter in each rail (one by one ) , between cap bank and pcb and measure - without mosfets you'll have up to 20-30mA , no more
with mosfets - increased for Iq
Old 27th August 2014, 05:41 PM   #95
pmchoong's Avatar
Hi ZM. You mean ground the inputs all the time until it is ready to sing?
The board vibrates with and without the mosfets connected. It wasn't there before.
So, one probe on the negative rail and one probe on the negative of the amp board pcb to test the ampere and then repeat the same for the positive rail, is this correct?
Old 27th August 2014, 06:55 PM   #96
Zen Mod's Avatar
Rising DC Offset
yup
that's confusing .......
yup
find some tutorial on web , how to make basic measurements
look here , for instance :Basic Car Audio Electronics
look at right menu - Digital Multimeter
Old 29th August 2014, 03:48 PM   #97
pmchoong's Avatar
i have 0.54 mA on the negative rail and 0.21mA on the positive side.
Old 29th August 2014, 06:14 PM   #98
Zen Mod's Avatar
Rising DC Offset
you mean - one pcb is drawing 0,54mA from pos and and 0.21mA from neg rail ?
with JFets in place , just mosfets removed from circuit ?
Old 30th August 2014, 04:40 PM   #99
pmchoong's Avatar
Yes, please see attached picture on how I took the measurement.
Yes, with JFets in place and mosfets removed from the circuit.
as I said :
Should I take the measurement as in picture 'fets measurement.png4'?
Thanks, ZM.
Old 30th August 2014, 04:46 PM   #100
Zen Mod's Avatar
Rising DC Offset
that right one
Rising DC OffsetHide this!Advertise here!
What is DC offset? spooney Car Audio 16 9th September 2013 01:32 AM
Dc offset Vrystaat Solid State 9 14th May 2013 07:16 PM
DH-220 Clone (SMART TA-242) can't adjust DC offset using offset bias pot? beady Solid State 6 17th March 2011 11:53 AM
DC Offset JannaCassandra Chip Amps 3 26th July 2008 04:20 PM
Rising DC voltage DragonMaster Power Supplies 4 24th April 2008 04:55 PM
