High power resistors
Old 12th January 2004, 10:00 PM   #1
Magura is offline Magura  Denmark
Magura's Avatar
Default High power resistors
Wouldnt it be possible to use a monster mosfet in a to-264 package rated 300W as an adjustable bias resistor that has to dissipate 200W??
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 12th January 2004, 10:16 PM   #2
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Sure, as long as the transistor chip not gets too hot... but this is not an easy task.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: SSR03 Super Regulator Power Supply. Sign up HERE 72 pcb's ordered, 72 paid. Still possible to sign up.
Old 12th January 2004, 11:13 PM   #3
Steven is offline Steven  Netherlands
Steven's Avatar
Why use transistors with all their temperature problems when you can use resistors? Resistors are allowed to get a lot hotter. I think of using these new planar resistors. They do not use an additional heatsink, are small enough, can dissipate 100W at 25*C and are allowed to go to 350*C. Still you can mount them on a PCB.
Example below is from Nicrom-electronic, but such devices are also manufactured by Ohmite, BI technologies, and RCD components. Now I only have to find a distributor that sells them in small quantities. Anyone?
Steven
Old 12th January 2004, 11:22 PM   #4
Christer is offline Christer  Sweden
Magura,
with that signature, why do you even ask?
Adding to Stevens comment. Caddock also makes a few types
of rather small film-based resistors. Can't remember the
model numbers now, but check ut Elfa, they carry them.
Old 13th January 2004, 02:56 PM   #5
Magura's Avatar
How exactly would that be done...it sounds like you have an idea???
Cheers
Magura
Old 13th January 2004, 03:14 PM   #6
joensd is offline joensd  Germany
If you mount a big fan directly over them, they even might not desolder themself and stay on the PCB.
Old 13th January 2004, 03:22 PM   #7
Magura's Avatar
I too found it hard to implement them in something for my living room....i sure like the option to keep them sub 175C
Magura
Old 13th January 2004, 06:06 PM   #8
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
I don't want you to think that I regard light bulbs as the
solution to all problems, but they make great power resistors,
and you can vary the values by paralleling several and
unscrewing the ones you don't want. I use this to put the
Zen Lite into low power mode, unscrewing 2 or 4 of the 6
light bulbs.
Old 13th January 2004, 07:37 PM   #9
Steven's Avatar
Magura
When it comes to heating your room, I think it makes no difference whether you dissipate 100W in a huge heatsink mounted monster mosfet with the heatsink at 100*C, or in a relatively small resistor that can be 350*C, or even in a small halogen bulb that can be 2500*C. It's just 100W.
If you care about the accuracy of the resistor over the temperature range I'm sure these thick film ruthenium oxide resistors win. They change less than 5% over the complete temperature range from 25*C to 350*C. Power derating is linear from 100% at 25*C ambient to 0% at 350*C.
Inductance is also extremely low at <50nH.
I'm not 100% sure, but I have the impression that you can use them at full power without auto-desoldering from the PCB. The stands are designed with low heat conducting properties. Maybe you need a few square cm of copper area on the PCB for each stand.
Steven
Old 13th January 2004, 07:45 PM   #10
Magura's Avatar
What i meant was that its a lot nicer to have something like a heatsink at 65C than a resistor at 300C in your living room. I would like a sealed box, in order to avoid dust and whatever else that usually resides in an old amp
A sealed box prevents me from using anything i cant mount on a heatsink or outside the box
Cheers
Magura
High power resistorsHide this!Advertise here!
Do we really need high priced "audio grade" power resistors? panson_hk Parts 11 14th June 2016 11:14 AM
High quality capacitors, resistors Vortex Parts 2 6th March 2004 04:34 AM
High Power resistors for Son of Zen for sale Cheap! webercarbmann Swap Meet 4 24th February 2003 11:15 AM
Wanted: high-end resistors vdi_nenna Swap Meet 0 3rd February 2001 11:18 PM
Copyright ©1999-2017 diyAudio
