Aber gerne !
Looks good although if I had to make it again I would put MOSFETs on shorter sides of PCB to add some more space between them, like this (post #963 and #972) :
http://www.diyaudio.com/forums/pass-labs/121228-f5-power-amplifier-20.html#post1525502
Anyway, it's not critical here because power supply voltage is +/-16V and the Id is about 0.8A, so Pd per MOSFET is 13W only.
Power supply. I´ll go mono and 2 versions: with CMC (WE) or resistor (SMQ). Schottkys are FSV1045V.
JP
JP
well... done!
Will build it for a friend (2SJ74GR, 2SJ162, 2SK1058 Reichelt, 2SK170GR Dönberg).
Ok, let make the power supplies...
JP
are you sure that they aren't fake?
especially the j74 and k170
hello Dennis,
i am thinking of common source topologies, while cubie3 is common drain.
in my opinion common source has a magical sounding, like F5 amp.
hello Juma,
if i want to build this cubie for 50watt output power
how many pairs do i have to pararel the output TR?
is it still the same voltage rails and bias settings?
50W @ 8R means higher voltage power rails and cascoding JFETs at least, so it would be practically a new design.
Just adding more output pairs would take you to 50W only if you use very low Z speakers (1-2 R)
- Cubie - small F5 variant with GR grade JFETs and LatFETs
