The diyAudio Firstwatt F6
Old 10th June 2018, 03:57 PM   #1881
kbergsson is offline kbergsson  Iceland
kbergsson's Avatar
Originally Posted by silasmellor View Post
Only to occupy your hands all the more reason to keep building things...
Correct Silasmellor Im currently thinking of a chassis for M2 monoblocks and really like how the Hiraga Monsters and for example the Pioneer M22 class A from the eighties where built. More in the tube style with exposed caps and trafoboxes. I really lusted for the Hiraga amps when I was studying in Dk in the eighties. Couldnt afford the amps or the right speakers at the time and eg the Acoustas with the 8 inch Corals, which I could have built, where to thin sounding for my taste. I did assemble the Klifoth Onkens ( with the plaster egg) for a friend, they would have been great partners for the Monsters.
Old 10th June 2018, 07:04 PM   #1882
chede is offline chede  Germany
... fascinated by amps
chede's Avatar
Originally Posted by kbergsson View Post
... I tried yesterday to exchange my Aikido linestage ( ca 10-15 db gain, using 4x 6cg7 tubes) with a Slagle autoformer box ( used as my pre for many years in front of SE 300B amps). ...
You could try re-configuring your Aikido as an Aikido Cathode Follower (ACF), which mainly acts as a buffer.
I did that by pulling out the first tube, the one that provides all the gain. The only thing that I then needed to do then was connecting the two connections in the empty socket where grid and plate of the lower half of the tube would have been going with a capacitor. 220 nF to 1 µF is fine, and voltage rating must be sufficient for the full B+.
in the attached schematic, the left socket would be empty, and the capacitor would go between pins 1 and 2.
The diyAudio Firstwatt F6-aikido-wullie-pcb-jpg
Just try it ... it's an interesting alternative. It gives me enough gain in most situations (M2 into 100dB/W efficient Jericho Horns), and has about half the distortion of a regular Aikido.
Just remember that the regular Aikido is inverting, but the ACF is not ...
Best regards,
Claas
Old 10th June 2018, 07:16 PM   #1883
kbergsson's Avatar
Thanks Claas, I will try this on my Aikido.
The diyAudio Firstwatt F6Hide this!Advertise here!
F6 Amplifier Nelson Pass Pass Labs 6607 24th January 2018 05:36 AM
Help with HiVi F6 in a 2-Way GOR3 Multi-Way 3 10th July 2013 12:15 PM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
diyaudio moderator vs diyaudio member Leolabs Everything Else 6 18th June 2006 08:19 AM
