The diyAudio Firstwatt F6
Old 1st August 2017, 09:04 PM   #1801
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
Originally Posted by fabrice63 View Post
Is this "new" F6 been tested "musicaly" and "sonically" and mesured before , or it is one more F6 on the road , and what 's Nitrous for , I did not follow the entire story !!!
just wonder if it's a step forward
You can make it sound anyway you want.
You can build it exactly like the original circuit or any of the variations in the F6 article or even with 40V rails if you wanted, that's the reason for adding nitrous.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 2nd August 2017, 09:45 AM   #1802
fabrice63 is online now fabrice63  France
fabrice63's Avatar
Got it , Thanks
Old 12th August 2017, 04:17 AM   #1803
bk856er is offline bk856er  United States
bk856er's Avatar
Originally Posted by Nelson Pass View Post
For M2's, I just bought some mu metal (by the foot) from McMaster-Carr
and folded it.
Worked fine, very cheap, quick delivery.
Would that be the 0.01" thick, 4" wide material? I'm curious to try this.
BK
Old 12th August 2017, 06:15 PM   #1804
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
I forget, but it sounds like it.
Old 17th August 2017, 02:38 AM   #1805
bk856er's Avatar
Thx. Received today from McMaster (4x12x0.01") impeccably packaged, $74 delivered. Now in hand I see that it's a special material and worthy of doing it right. Will update with results. M2 primarily, maybe also F6 (clones).
BK
Old 18th March 2018, 09:19 PM   #1806
silasmellor is offline silasmellor  Denmark
bk856er, did you get to try this on your F6? I am troubleshooting some buzz and wonder if shielding the input transformers might something to go for, so would be curious to hear what your results were.
Old 19th March 2018, 05:30 AM   #1807
bk856er's Avatar
Sorry, the sheet material is still sitting on the bench waiting to be cut and shaped into a cute little box, so can't speak from experience here!
BK
Old 11th April 2018, 10:17 AM   #1808
fabrice63's Avatar
Hi all,
I finally give my F6 some nice almost perfect matched IRFP240 , and here are the distortion numbers that came out , using an UCA222 calibrated sound card .
test made at 1 Watts , with 8.0 ohm non inductive load , 0.500 v bias , R1 and R2 0.47 ohm
Old 23rd April 2018, 09:10 AM   #1809
tower2010 is offline tower2010  Spain
Originally Posted by Zen Mod View Post
here it goes
BC546/556 ,BC547/557 , BC550/560 , ZTX450/550
also - increase mosfet gate resistors to , say, 220R
Hello,
Has anybody tried Turbo version proposed by Zen Mod? I would like to know if it is feasible and how it sounds...
It would nice a similar approach for M2
Thanks.
Old 10th May 2018, 09:27 AM   #1810
forgehammer67 is offline forgehammer67
Hello everyone.
I would like build an amp diy, it will be my first achievement so i'm looking for a relatively simple amp to build. This would be to power Klipsch RF7-MKII speakers. These speakers require an amp sound rather soft and warm, or at least not aggressive in the medium-high frequencies.
I think to realize the Firstwatt F6 or F5. Do you think that these amp would make a good association with Klipsch RF7-MKII.
Thanks for your advices.
Thierry
The diyAudio Firstwatt F6Hide this!Advertise here!
F6 Amplifier Nelson Pass Pass Labs 6607 24th January 2018 05:36 AM
Help with HiVi F6 in a 2-Way GOR3 Multi-Way 3 10th July 2013 12:15 PM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
diyaudio moderator vs diyaudio member Leolabs Everything Else 6 18th June 2006 08:19 AM
