The BA-3 as preamp build guide
Old 9th March 2018, 07:52 PM   #901
6L6 is offline 6L6  United States
6L6's Avatar
Huh! Look at that - the current one on the website (v2.1) does use opamps, but the schematic linked in the manual above doesn't. I was really confused for a few min looking at the old schematic...
Originally Posted by Hikari1 View Post
The TP Placid uses opamps which is why it's probably voltage limited.
Old 12th March 2018, 03:56 PM   #902
woofertester is offline woofertester  United States
I am going to build this project for a very good friend. He is a golden ear audiophile and has designed speakers for some big names. He is now 81 and cannot solder so he asked me to build him a new preamp. His highly modded Dynaco PAS died.
The boards and many of the puzzle pieces are on order. I will build it on a piece of plywood to test everything before building it into a case.
The initial plan is to be completely dual mono. Separate transformers and power supplies for left and right channels.
His system is all BNC so I will carry over his I/O jack plate or disassemble and install individual jacks.
Old 15th March 2018, 05:24 PM   #903
Manolo47 is offline Manolo47  Puerto Rico
Default How to dial P1 and p2 to 0 ohms
Sorry for this question, but I'm not sure how this goes.
Measure from outer leads?
Doesn't look that too much variance is happening..
Thanks.
Old 15th March 2018, 05:59 PM   #904
Russellc is offline Russellc  United States
Thanks.
If I remember correctly, I am pretty sure I set mine in the middle of the range....usually they come that way. if unsure, twist one way until it clicks. Then twist the other way until it clicks again, counting each revolution....then turn back 1/2 of that number.
Russellc
Pass B-1 preamp, Pass BA3 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Amp, Pass M-2 amp, Pass Aleph J amp, Pass Pearl 2 Phono pre Tekton Enzo, Altec A7, Econowave JBL 2235H & B&C CD
Old 15th March 2018, 06:07 PM   #905
silasmellor is online now silasmellor  Denmark
If you look at the boards, only 2 of the 3 pins are actually used, so just measure the resistance between those two and set to the desired value.
Old 15th March 2018, 06:11 PM   #906
KevinHeem is offline KevinHeem  United States
KevinHeem's Avatar
Thanks.
You need to be on the middle leg and one outer legs to read a varying resistance. You can zero it out in either direction so it depends on which way you orient the pot. Easiest thing to do is solder the pot in and then measure across C1 using P1 to zero it out. do the same at C2 using P2.
Old 16th March 2018, 05:18 PM   #907
Default Isolation washers
Do I need to to install isolation washers in the bolt/nuts between the output mosfets heat sinks and the bigger heatsinks, which would be really extensions of the latter?
Thanks.
Old 16th March 2018, 05:20 PM   #908
6L6's Avatar
Bigger heatsinks? I don't follow...
Old 16th March 2018, 05:42 PM   #909
Its between the interface between the output mosfet and the heatsink...
The mosfet also has a heatsink...
Old 16th March 2018, 05:49 PM   #910
6L6's Avatar
That't not a heatsink - it's the case and electrically connected to drain.
So yes, you need to insulate the Mosfet front the heatsink using mica and grease, keratherm, or some similar insulator.
These work beautifully - Keratherm Transistor Insulators – diyAudio Store
The BA-3 as preamp build guideHide this!Advertise here!
BA-3 As Preamp vdi_nenna Pass Labs 1322 16th July 2018 12:23 AM
MyRefC build guide AndrewT Chip Amps 1119 29th July 2016 10:30 PM
Trapezoid build guide? mudchute Planet 10 hifi 22 10th November 2014 09:37 AM
MY FIRST BUILD BA-1 joesch1999 Pass Labs 15 15th May 2011 08:54 PM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
