The BA-3 as preamp build guide
Old 27th July 2014, 07:25 PM   #21
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
"across" , pretty important part of the puzzle
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 27th July 2014, 07:29 PM   #22
delecoy is offline delecoy  United States
delecoy's Avatar
Now have both channels at 55ma across R10...still no offset across R12. The circuit is not responding to P2 at all.
Old 27th July 2014, 07:41 PM   #23
Zen Mod's Avatar
offset is not same as voltage
so , you're looking for voltages at some nodes (ref. to gnd) or voltages across some parts ......... but offset is ( by consensus) usually voltage at output , ref to gnd
gimme voltages at both Jfet drains , ref to gnd , same as voltages at both JFet sources ...... P3 in mid position
Old 27th July 2014, 07:54 PM   #24
delecoy's Avatar
Channel 1: Q2 drain to ground is 23.8V, Q1 drain to ground is -21.6
Channel 2: Q2 drain to ground is 23.8V, Q1 drain to ground is -21.6
The exact same?
Old 27th July 2014, 07:56 PM   #25
Zen Mod's Avatar
sources ?
Old 27th July 2014, 08:08 PM   #26
delecoy's Avatar
Channel 1: Q2 source to ground is 60.1V, Q1 source to ground is -68.8V
Channel 2: Q2 source to ground is 61.4V, Q1 source to ground is -68.0V
Offset on channel 1 at the RCA output is bouncing around 0 - 20 mV
Offset on channel 2 at the RCA output is bouncing around 0 - 20 mV
Old 27th July 2014, 08:22 PM   #27
Zen Mod's Avatar
60V ?????
something's very fishy there !
you didn't mixed PSU rails ?
Old 27th July 2014, 08:23 PM   #28
delecoy's Avatar
Starting over measuring offset in volts at output
Old 27th July 2014, 08:25 PM   #29
Zen Mod's Avatar
take a break , proceed tomorrow
or , maybe it's just me - I can't follow and find any logic , if trusting in #26
Old 27th July 2014, 08:47 PM   #30
delecoy's Avatar
Im thinking you had it in #23. I was looking to measure offset in the wrong place, increased the bias without decreasing offset, and may have zapped my jfets. Now measuring 0 at the source.
The BA-3 as preamp build guideHide this!Advertise here!
BA-3 As Preamp vdi_nenna Pass Labs 1263 8th April 2018 06:06 PM
MyRefC build guide AndrewT Chip Amps 1119 29th July 2016 10:30 PM
Trapezoid build guide? mudchute Planet 10 hifi 22 10th November 2014 09:37 AM
MY FIRST BUILD BA-1 joesch1999 Pass Labs 15 15th May 2011 08:54 PM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
