The BA-3 as preamp build guide
Old 23rd June 2014, 11:14 PM   #11
bcmbob is offline bcmbob  United States
Originally Posted by 6L6 View Post
None.
The power amp would have a few sets of input jacks, a selector switch and a pot. It doesn't need to be any more complicated.
Thanks. After thinking of the BA-3 Pre as a line stage (as stated in your post) I see attenuation only from the pot. Wasn't sure if any DC blocking needed to be added to the input of the output section/chassis in case a non-well adjusted Pass FE might be connected. Sounds like making the output stage independent/self-contained would be an interesting project on it's own. There are probably several examples of such somewhere around the forum.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 23rd June 2014, 11:28 PM   #12
6L6 is offline 6L6  United States
6L6's Avatar
Yes. You can find it here -
FIRST WATT F4
A guide to building the Pass F4 amplifier.
Old 23rd June 2014, 11:43 PM   #13
Bob M.
Old 27th July 2014, 10:17 AM   #14
SjoerdSmits is offline SjoerdSmits  Netherlands
SjoerdSmits's Avatar
Any PCB available anywhere?
Cheers!
Old 27th July 2014, 10:58 AM   #15
6L6's Avatar
Yes - P-BAGSN-1V20 - Burning Amplifier Gain Stage for BA-3 (Requires bias boards and output stage; Makes 2 channels; Rev 2.0) - Circuit Boards
(Currently out of stock, there should be a reorder soon.)
Old 27th July 2014, 06:33 PM   #16
delecoy is offline delecoy  United States
delecoy's Avatar
Have my BA-3 FE up and running, and biased to about 45mv. But, I've observed no DC offset on R11 for either channel. Is this possible?
Old 27th July 2014, 06:39 PM   #17
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
R11 ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 27th July 2014, 06:45 PM   #18
delecoy's Avatar
Thank you for the quick response!. 0 at r12 too. So 45mv at R10, 0 and 0 at R11 and R12. Circuit is built exactly according to the original article, Toshibas all the way around, 9.6 ma for the matched jfets. Q3 and Q4 are not matched. I just set up my F4 last weekend and had to play with the bias and offset to get it right. So I was very surprised to see no offset on the BA3-FE. I have to have missed something somewhere. Set the bias the first time around with the input shorted, Then tried again without it shorted. Still no offset.
Old 27th July 2014, 06:48 PM   #19
delecoy's Avatar
PSU is reading 24.0 and -24.2. Is the Peter Daniel universal board with LM317/337 regulators.
Old 27th July 2014, 07:07 PM   #20
delecoy's Avatar
I see now. Sheesh...45ma...1 volt across R10, not 45mv.
The BA-3 as preamp build guideHide this!Advertise here!
BA-3 As Preamp vdi_nenna Pass Labs 1322 16th July 2018 12:23 AM
MyRefC build guide AndrewT Chip Amps 1119 29th July 2016 10:30 PM
Trapezoid build guide? mudchute Planet 10 hifi 22 10th November 2014 09:37 AM
MY FIRST BUILD BA-1 joesch1999 Pass Labs 15 15th May 2011 08:54 PM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
