The BA-3 as preamp build guide
Old 3rd August 2018, 10:25 PM   #1041
MEPER is offline MEPER  Denmark
Yes, I have read the article now. I think I understand more and more about JFET operation. Also good to see that output mosfet does not need huge heatsinks. So the 15 K/W I have may work if I just run them at normal bias.
Old 4th August 2018, 12:33 AM   #1042
Russellc is offline Russellc  United States
Originally Posted by MEPER View Post
I have ordered an octet. He writes that they are in the 7 mA range.....should be OK I guess (hope)…….
I did the same thing, just discussed it with him first, the "7ma range" he has has some sets closer to 8ma, so I noted for those. I think original article called for 10ma, and a few resistor/pot changes can make a wide range usable. he has them marked on package what measurement they are.
Russellc
Pass B-1 preamp, Pass BA3 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Amp, Pass M-2 amp, Pass Aleph J amp, Pass Pearl 2 Phono pre Tekton Enzo, Altec A7, Econowave JBL 2235H & B&C CD
Old 4th August 2018, 12:42 AM   #1043
Originally Posted by Hikari1 View Post
Yes, anything BL grade will work.
Yup, "These JFETs were chosen at Idss
figures of 10 mA (Idss is the current that flows when the Gate and Source are at the same
voltage). If you get lower values, you may want to consider higher values for P1 and P2, say
1 Kohm. They are best matched, but P3 can be adjusted to compensate for some mismatch".
I like to get around 8, everything worked with standard values....
Russellc
Old 4th August 2018, 10:28 AM   #1044
vcec is offline vcec
ZenMod:
article , here , if you want addendum
Burning Amplifier BA-3
addendum - -look down at comment #15 , by Mighty Moi :
Thanks ZenMod - just what I was after!
Cheers
Old 10th August 2018, 05:17 PM   #1045
ggetzoff is offline ggetzoff  United States
ggetzoff's Avatar
Originally Posted by Zen Mod View Post
BA3 FE is really at its best when mated with BA3 OS , so working in full gain/swing mode
when adjusted to work as line preamp , it's somewhat constipated
so , it's really best to make it as part of power amp , then use anything simple as line stage - even just decent pot or pot plus buffer will work as charm
Or as Papa hints in the BA-3 article, just make it a power amp itself. The Toshibas are good to 25W.
Airline Pilot-If it's not Boeing I'm not going.
Aleph J, DCB1, VHEX + USSA-5, BA-3 Pre, DCG3
Old 10th August 2018, 05:19 PM   #1046
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
I would leave heavy duty work for output buffer , still
leaving Toshibas in happy realm
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
The BA-3 as preamp build guideHide this!Advertise here!
BA-3 As Preamp vdi_nenna Pass Labs 1322 16th July 2018 12:23 AM
MyRefC build guide AndrewT Chip Amps 1119 29th July 2016 10:30 PM
Trapezoid build guide? mudchute Planet 10 hifi 22 10th November 2014 09:37 AM
MY FIRST BUILD BA-1 joesch1999 Pass Labs 15 15th May 2011 08:54 PM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
Resources saved on this page: MySQL 66.67% / PHP 84.03%
