Heat issue zen Lite - diyAudio
Old 8th June 2014, 08:03 PM   #1
Dan P is offline Dan P  Sweden
Default Heat issue zen Lite
Hello !
I posted this question in an earlier thread but I try again.
it is normal for the coil in the Zen lite to get hot. I measured the temperature to + 80 C after 30 minutes. I installed a cooling fan and the temperature dropped to 60 C.
I could not get a 14 gauge 4mH (1.63 mm) coil in Sweden. My coil is made by 1.4 mm wire. Is the high temperature normal or not ?
The caps are slightly lower 20000 uF instead of 25000 uF. (the Circuit och powersource) Does this generate heat in the coil ?
Dan P
Old 8th June 2014, 08:08 PM   #2
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
The temperature is loss of power as some of the power is now heat. Try using double wound 0.8mm or even larger but I think the loss could be in any core used due to eddy currents
Support for Flying Mole, Allen & Heath, Valve amps, older designs & 2CVs. www.jonsnell.co.uk
Old 9th June 2014, 08:28 AM   #3
indra1 is offline indra1  Indonesia
Originally Posted by Dan P View Post
. . . I could not get a 14 gauge 4mH (1.63 mm) coil in Sweden. My coil is made by 1.4 mm wire. Is the high temperature normal or not ? . . .
Hi, Dan,
An air core 4mH coil made of 1.4mm wire should be good up to about 2.5A DC Iq, you can use 4 units in serial parallel combination to help heat distribution, but I think we need more info than that to be able to help you further, there could be something else wrong that causes excessive dissipation.
- DC Iq passing through your coil and DC resistance of your coil
- exact circuit you use, zen lite have many variations
- whether your coil suitable for DC - how your coil is made - air core, gapped EI iron core or...
- Pictures should help
Old 5th July 2014, 07:48 PM   #4
Hello !
I just measured my Zen Lite when I uppdated to bigger internal fans.
The current through the Coil is 5.1 A
Internal resistance measured to 2,3 Ohm
DC meassured 4.2 Volt
The variations I buildt was the balanced version (FIG 16) zen Lite.
4 bulbs 300 W
Toroid specs 800 VA 2x53 Volts
The coil is an air coil with 1.4 mm Cu.
Rdc 066.
I hope this helps to sort out the heat problem.
best regards
Dan P
Old 5th July 2014, 08:00 PM   #5
DC meassured 4.2 Volt . . . .
??? 5.1x2.3=11.73<>4.2V
Rdc 066.
So which is it Dan 2.3 or 066?
Old 5th July 2014, 08:22 PM   #6
The measured value is 2,3 Ohm over the coil with my multimeter.
0.66 is taken from the homepage were I bought the coil.
Best regards Dan P
Old 5th July 2014, 08:30 PM   #7
Ok Dan, but your meter has problem, invalid reading, the number does not add up.
However, as I stated previously, 1.4mm is good up to 2.5A, for 5.1A you need at least 2 in parallel. But now you have 2mH instead of 4mH. Try it first, if you don't like it, you can add 2 more in parallel in series to the first 2 to get 4mH back.
Old 5th July 2014, 09:01 PM   #8
Hello !
Thanks for the help.
I will try with new coils. Depending on waht I will find.
Dan P
Old 7th July 2014, 08:47 AM   #9
You may want to just build a Mosfet cap multiplier. You would just lose about 4.5v in the regulator. lower your ripple more and might even be cheaper.
Old 7th July 2014, 09:00 AM   #10
it is normal for the coil in the Zen lite to get hot. I measured the temperature to + 80 C after 30 minutes......................
I could not get a 14 gauge 4mH (1.63 mm) coil in Sweden. My coil is made by 1.4 mm wire.................... Does this generate heat in the coil ?...............
............I just measured my Zen Lite when I uppdated to bigger internal fans.
Internal resistance measured to 2,3 Ohm................
Yes, it gets very hot.
5.1Adc through 2r3 is 59.8W !!!!!! in the coil.
For wire in an airstream with normal electrical insulation you can use 3.1A per sqmm.
1.63mm diameter has a current rating of ~6.5A when cooled by the air stream.
1.4mm diameter has a current rating of ~4.8A when cooled by the air stream.
Your "coil" will have many turns insulating each other from the cooling air stream
The acceptable current rating will be much lower than 3.1A per sqmm. Maybe less than half that value.
A good clue is the resistance of the coil and Vdrop.
0r1 will dissipate ~2.6W
0r5 will dissipate ~13W
1r0 will dissipate ~26W
But, that 1r0 will drop 5.1V. Can your circuit perform properly with a 5.1V loss between the supply and the circuit?
2r3 will drop ~11.7V !!!!!
P=IV = 5.1*11.7
regards Andrew T.
Testing the Zen-Lite Dan P Pass Labs 14 18th April 2014 09:27 PM
Zen Lite and Heatsinks skidave Pass Labs 5 9th May 2007 07:15 AM
Zen lite chrille Pass Labs 10 15th February 2003 09:02 PM
son of Zen-lite PedroPO Pass Labs 23 25th July 2002 09:28 AM
bulbs for the Zen lite Selfmade Pass Labs 2 15th February 2002 10:10 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
