Thinking About Building A Class A Amp, But Have Some Questions
Old 10th January 2004, 06:01 AM   #1
li_gangyi is offline li_gangyi  Singapore
li_gangyi's Avatar
I'm a newbie and would like to try one of those Class-A amps I've been hearing so much about...what kinda PSU are wqe looking at since class A has got low noise rejection?? and why do we use Mosfets instead of Bipolars...is Bipolar usuage possible?? and of course are matched stuff very important?? Sorry for a bit of OT...I understand these amps are at best 45% efficient (if it ever gets there...) so I'll need some BIG heatsinks....
And is building WITHOUT a PCB possible?? I.E I just mount everything on the Heatsinks since the circuit I've seen are pretty easy...and what kinda schematic are we looking at for the Aleph3?? sorry again for the many dumb0 questions...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 10th January 2004, 06:17 AM   #2
li_gangyi's Avatar
Oh...thanks moderator for shifting me to a better place...
Old 10th January 2004, 09:48 AM   #3
Circlotron is offline Circlotron  Australia
Circlotron's Avatar
If the output stage is a source follower or emitter follower then the power supply noise rejection will be very good. Just make sure the earlier (low current) stages have a noise-free supply rail. That's easy.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 10th January 2004, 11:30 AM   #4
li_gangyi's Avatar
hmm...so what kinda circuit are we looking at for the best noise rejection assuming I'm gonna scrimp on my PSU section for testing...
Old 10th January 2004, 06:06 PM   #5
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
For testing purposes, you can scriimp all you want. In fact,
this will give you a thumbnail value for how clean your supply
will want to be when you build the real thing.
Old 11th January 2004, 02:46 AM   #6
roddyama is offline roddyama  United States
diyAudio Moderator Emeritus
roddyama's Avatar
Li,
The answers to most of your questions can be found at the Pass Labs site here:
http://www.passlabs.com/aleph.htm
There are all the owners and service manuals for all the Aleph series amps. You also want to look at some of the early articles on class A designs. The articles on the Zen amps can be found at the PassDIY site here:
http://passdiy.com/amps.htm
Have fun,
Rodd Yamashita
Old 11th January 2004, 04:21 AM   #7
GRollins is offline GRollins  United States
Use differentials in the front end and you'll acheive a certain amount of immunity to PS noise. Current sources can help also. Class A amps need not be sensitive to noise. After all, the front end in class A/B and class B amps run in class A already. After that, it's only a question of how to bias the outputs.
Certainly bipolars are possible. So are tubes, for that matter. Lots of class A amps were build before MOSFETs became practical devices.
Although I don't generally run point-to-point wiring myself, there's no reason a class A amp can't be done that way.
Grey
Old 11th January 2004, 04:21 AM   #8
li_gangyi's Avatar
I've been looking at the DoZ thingies...seems like they are the easiest to implement...probably gonna use some Bipolars instead of MOSFETs...dun really like them...anyone care to "push" me towards MOSFETs?? Hehe...I did use MOSFETs in a Class A Headphone amp once...sound was very clear but at high volumes it sounded kinda "fake" dunno if it's my PSU sagging therefor inducing some compression though...
Old 11th January 2004, 04:34 AM   #9
li_gangyi's Avatar
Oh yeah...and thanks to everyone for their help and especially the moderators for helipng me shift this thread...looking forward toi my first Class A big time amp...maybe I'll drop GC and ABs after this...
Old 11th January 2004, 01:10 PM   #10
MikeW is offline MikeW  United States
MikeW's Avatar
Default Build an Aleph
There is a lot of information. You can build anything from 15 to 100 watts if you have heatsinks. The motherboard is the same except for some resistor changes. Use the MOSFETS. You will like them. If you have a hard time getting them I would be glad to send you a few.
MikeW
Thinking About Building A Class A Amp, But Have Some QuestionsHide this!Advertise here!
Thinking about a new DIY uni-pivot arm, but I have questions Phileas Fogg Analogue Source 14 13th November 2007 08:37 AM
thinking about building my first cabinet spc18 Full Range 1 10th July 2007 01:44 AM
Thinking about building an OB using ironwood (ipe) owdi Multi-Way 31 18th January 2007 03:46 AM
NOOB! Thinking of building a 4 ch 3875 amp - questions.. quickshift Chip Amps 7 7th August 2005 01:57 PM
Thinking of building my first tube amp. Suitable projects? Erik Johansson Tubes / Valves 55 8th April 2002 11:28 PM
Copyright ©1999-2017 diyAudio
