Recommendation for 5-10W amp. - Page 27 - diyAudio
Old 11th August 2014, 04:39 AM   #261
e_fortier's Avatar
Thanks Fab.
The amp does not have any bottom and I left a space of 6mm between the heatsink and the Plexiglass. I'll run some temp test tomorrow. If it heats up I'll become creative with the press drill...LOL
Rgds,
Eric
Old 22nd August 2014, 04:48 PM   #262
cwtim01 is offline cwtim01  Hong Kong
cwtim01's Avatar
I made one channel of the mini-F5 for testing, with component values according to the attached schematic. Except that I used a 19.5V notebook smps to power the circuit while testing, since I'm still waiting for the toroid to be delivered.
The amp seems to work, I fed it with a 2.8Vpp sine wave from my scope meter and it's amplified (in fact, it clipped but the generator output from my cheap scope meter is fixed at 2.8Vpp so cannot lower it.)
However, I have an issue. I noticed that Vgs of Q4 is only 0.89V and Vgs of Q3 is only -0.53V. That correspond to around 140mA of bias, too low actually. So I want to know whether I should increase R3 and R5 to get higher Vgs, or this is simply due to the use of the 19.5V supply, and will be fixed when a 24V supply is used (I would like to have around 750mA of bias current).
Thanks and regards.
Old 22nd August 2014, 05:51 PM   #263
e_fortier's Avatar
Nice looking PCB.
In my amp R3, R5 are 1K1 (with a 24V supply) but that is because my NOS LatMOS seems to be lazy.
Before changing R3 and R5 and would wait to use your 24Vdc supply.
I think your low bias is mostly due to a low supply. Do you own a small bench test 24V supply ?
Rgds,
Eric
Old 23rd August 2014, 01:20 AM   #264
cwtim01's Avatar
Thanks, I don't have a bench top power supply yet, but this is certainly on my to-buy-list for the future.
Old 23rd August 2014, 03:54 AM   #265
e_fortier's Avatar
This is the one I'm using presently. Maybe one day I will try a regular power supply, just maybe. I do not fear SMPS.
120W DC24V 5A Switching Power Supply ?Suitable for TK2050 Amp | eBay
Rgds,
Eric
Old 24th August 2014, 04:55 PM   #266
cwtim01's Avatar
Default It sings
It'll take another 2 weeks for the 200VA dual 18V toroid I ordered to be delivered, but I took an undersized 35VA dual 9V from a linear regulator to give the 24V dc I needed for testing.
At 23.8V Vcc, I got a bias of 500mA for each MOSFET, so I increased R3/5 from 680R to 820R. However, it was too much to ask for the tiny 35A toroid and Vcc dropped to 22V, anyway I got a bias of around 600mA with that.
Next I connected a 5R 20W resistor to the output as dummy load, and I saw oscillation from the scope meter when test signal was present. I removed the 4.7uF output bypass capacitor and the oscillation got even worse. It turned out oscillation was due to the nest of crocodile lead wiring mingled altogether, but was resolved by separating the input and output wires with proper distance.
Finally connected the test channel to a cheap Denon speaker, and it sings !! Source is just a Samsung smartphone's audio out, but even with a single channel the sound is quite nice, it has a taste of sweetness resembling that of tube amps
Old 24th August 2014, 05:23 PM   #267
e_fortier's Avatar
Great news !
I really enjoy this amp, if I build a second one I will modified the PCB for R3/R5 : fix 500 ohm in series with a 1K multi-turn pot.
BR,
Eric
Old 16th October 2014, 10:05 PM   #268
e_fortier's Avatar
Default Help please.
Hi all,
Since the amp has an output cap (C3) I always get a turn-on an off thump.
I decided to add a speaker protection module from e-bay that includes a upc1237.
It's much better, I do not have any turn-on thump but I still have a turn off thump if the following set-up. Please have a look at the attached diagram.
The amp is powered via a SMPS (24Vdc, 5A) and now it has a connection for a 12Vac input for the speaker protection module, both power are going through a DPST switch on the back of the amp. Both supply are connected into a single power bar strip.
If I close the power of the amp via the power bar switch (SW1) I do NOT get a turn-off thump.
If I close the power of the amp via the switch on the back of the amp (SW2) I do get a turn-off thump...
I shorted both inputs and it doesn't change the outcome.
I'd like to avoid having to close the amp by turning off the whole power bar.
Anyone knows what can be causing this odd behavior.
Thanks in advance for any suggestion.
BR,
Eric
Old 17th October 2014, 12:02 AM   #269
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
always put switch in lowest current loop
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 17th October 2014, 12:15 AM   #270
e_fortier's Avatar
So you are suggesting the 12Vac, that won't work.
The switch has to cut both the 24Vdc and the 12Vac.
BR,
Eric
Tiny PAM8610 10W+10W board problems trevmar Class D 29 6th May 2016 03:05 AM
my 10W POWER AMP. NEED HELP'' desertstorm Solid State 8 12th December 2013 12:19 PM
10W amp help Dprasad97 Chip Amps 2 13th April 2012 01:37 PM
10W suitcase amp famousmockingbird Tubes / Valves 16 20th August 2011 06:56 PM
Best possible 10W from chip amp Robert_66 Chip Amps 14 2nd November 2004 12:43 PM
Copyright 1999-2017 diyAudio
