Recommendation for 5-10W amp.
Old 1st May 2014, 05:45 PM   #11
e_fortier is online now e_fortier  Canada
e_fortier's Avatar
Originally Posted by juma View Post
So, it's a single rail 24V power supply, clean 5W cl. A amp that you want - Laterals at the output, different sounding than ACA, right ?
Exactly
Thanks a lot, much appreciated.
Eric
Old 1st May 2014, 05:50 PM   #12
e_fortier's Avatar
Originally Posted by fab View Post
This description fits more the one Nelson shown in post 3.
The last one from Juma should also be a good alternative although I would use double polarity supply to get rid of the big output cap...
Fab
Good idea but I have many single rail +24V supply that I want to put to use so I'll stick with single supply, plus I like the added protection of the output cap with my sensitive full range.
Thanks,
Eric
Old 1st May 2014, 09:57 PM   #13
mos57 is offline mos57  Italy
mos57's Avatar
This is what I like (sch. in attachment) - one more F5 modification.
And yes, C2 polarity should be reversed (drawing error).
Seem to me that C2 polarity is right since your circuit is a single supply type.
Indeed, to me it looks like a native dual power supply circuit and arranged pretty bad to work with a single power supply.
It seems that your circuit is not balanced at all in the actual operation, being that Q1 working as a CE amplifier while Q2 works as a CC amplifier. For which the two drive signals of the power mosfet are quite different.
Then, what is the purpose of using the network formed by R12, R13, C4, D1?
Old 1st May 2014, 11:16 PM   #14
juma is offline juma  Germany
juma's Avatar
Yes, you are right on that one, my mistake - I posted in a hurry...
If you put your mind into it, it can look like an ice cream, or whatever you want it to look like...
Look a little harder - both Q1 & Q2 are correctly polarized and are driving the appropriate LatFET from the collector and receive the feedback to emitter, so both work in Common Emitter mode.
I'm afraid that not understanding that one disqualifies you as a critic, but here it is:
R12/R13 create a voltage divider which central point is held stiff at 12V (half PS voltage) with C4 which filters the residual ripple from the rail and that is the voltage set through R14 to the bases of Q1/Q2 and through the feedback network to the drains of LatFETs. R14 predominantly determines the Zin of the amp (since the base currents of Q1/Q2 are very low) and D1 takes care of C4's discharge.
Build a quick prototype and be amazed how nice it works...
Old 2nd May 2014, 03:22 AM   #15
hazard500 is offline hazard500  Australia
John Linsley Hood designed a nice 10 watt amp. I have heard a diy version - sounded very nice indeed.
Old 2nd May 2014, 03:49 AM   #16
e_fortier's Avatar
I'm already presently working on a JLH, the one from Silicon Ray with dual rail voltage.
For fun, so far it looks like this.
Eric
Old 2nd May 2014, 11:12 PM   #17
e_fortier's Avatar
Hi Juma,
Since this is your design, how did you built it..via perforated board, PCB or p2p. Just wondering if a PCB already exist for your design.
Is there an existing PCB for another project that has similar amplifier topology.
Thanks,
Eric
Old 3rd May 2014, 12:21 AM   #18
juma's Avatar
Here is the PCB I made for this amp - 46 x 57mm, copper side view.
It has provisions for bandwidth limiting caps in the feedback network and input LP filter cap (both in case of oscillations which didn't happen).
Output cap (10mF) is made out of 2 x 4700uF caps connected in parallel.
Input cap discharge resistor (220k) is placed on the input RCA connectors and the output cap discharge resistor (1k) is soldered on speaker terminals.
Old 3rd May 2014, 12:54 AM   #19
e_fortier's Avatar
Thanks a lot !
The last PCB I built from scratch (small amp) was back 25 years ago, time to get to work ;-) this will be fun.
Old 3rd May 2014, 02:51 AM   #20
e_fortier's Avatar
Hi Juma,
On your schematic (post no.8), R14 (47k) is connected on the left side of R18 (junction of C5).
On your PCB layout, I believe R14 is connected on the right side of R18.
Should R14 be connected to the left or right side of R18, does it make a difference ?
Thank you for your help.
Eric
Recommendation for 5-10W amp.Hide this!Advertise here!
Tiny PAM8610 10W+10W board problems trevmar Class D 29 6th May 2016 03:05 AM
my 10W POWER AMP. NEED HELP'' desertstorm Solid State 8 12th December 2013 12:19 PM
10W amp help Dprasad97 Chip Amps 2 13th April 2012 01:37 PM
10W suitcase amp famousmockingbird Tubes / Valves 16 20th August 2011 06:56 PM
Best possible 10W from chip amp Robert_66 Chip Amps 14 2nd November 2004 12:43 PM
