BOSOZ - P3 and P4, what if 20K?
Old 6th January 2004, 09:33 PM   #1
lgreen is offline lgreen  United States
lgreen's Avatar
Default BOSOZ - P3 and P4, what if 20K?
Here is yet another BOSOZ question:
If all I have is are 20K pots for P3 and P4 and want to use those as a volume control in BOSOZ rather than the 5K indicated in the circuit schematic, should I just go for it or are other circuit changes necessary? In particular I was thinking of changing R11 and R12 to something smaller than their listed value (100K) to compensate. Any thoughts? What are the tradeoffs?
Assume I'm driving a number of different amps, including Aleph 3 (23K ohm input impedance).
Old 7th January 2004, 06:57 AM   #2
Fox is offline Fox  Netherlands
Fox's Avatar
Hi Igreen,
What you could do is placing a 2 to 5K resistor in series with the signal after the 100k resistor to ground. After the 2 to 5 K resistor, you place the 20K pot between the signal and ground. Now you have just created an elegant shunt-attenuator.
With a 5 k series resistor you loose 2,5dB of gain, which may be to much. So it is probably best to take a 2K series resistor.
Hope this helps,
JP
BOSOZ - P3 and P4, what if 20K?Hide this!Advertise here!
To BOSOZ or not to BOSOZ... please comment. spence Pass Labs 4 27th February 2012 02:57 AM
Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? promitheus Pass Labs 87 19th February 2006 03:15 PM
X-bosoz vs. CCS X-bosoz, how does the sound compare? acliao Pass Labs 14 26th February 2004 12:55 AM
Bosoz lawbadman Pass Labs 5 14th July 2003 02:10 AM
10K Pot for the BOSOZ raincheck Pass Labs 13 20th September 2002 06:22 PM
Copyright ©1999-2017 diyAudio
