I am planning to build BoSoZ to drive Aleph-X. But since I don't have balance source, I'm going to operate the bosoz unbalanced-in to balanced-out. So, to keep the Vout+ and Vout- equal in magnitude, I replace R3-R6 with CCS. Iref and Iconst were set to be around 40mV, with Iref = 0.67V/R75.
With R75 = 17, Iconst (=Iref) will be approximately 39.4 mA. I attached the simm result here, and we can see that the CCS works nicely, so that Vout+ = Vout-. The simm shows the Iref = 41.912mA, and Iconst= 41.962mA. I run the simm with only one souce (Vs) because I wanted to operate it unbalanced in. Any sugestion/mods to this circuit? The simm looks OK, but I don't know the result in the real world. One thing weird about this circuit. I run the simm on Protel DXP, and each time I changed the value of R75 & R76 to, say, 17.5 ohms, the Vout and Iconst swings hecticly. At first, I thought that this circuit was not stable. But, I notice, when I change the value of R75/76 other than 17 ohms, the simm displays a warning: "Gmin stepping failed." What does this mean? I have already change the Gmin parameter before running the simms. Btw, what is Gmin parameter? Thx folks!
The Great Saiyaman Siapa bertelinga hendaklah ia mendengar... (Mat 13:9) |
#2 |
I forgot to mention. I run the Vs = 20 mV @ 1kHz. Actually, what is the typical magnitude of input voltage to a preamp?
#3 |
The one and only
Assuming that Iref and Iconst are just measurement
points for your simulator, it looks fine. Z3 and Z4 are superfluous, and there is no need for the negative supply rail to be so high. 20 volts would be more than enough. Also you could consolidate the current sources of Q3 and Q4 into 1 current source, feeding each Source 62 ohms. Also the negative input should be grounded, so short R14, the 100K resistor to ground. Everytime I look, I see something else..... |
#4 | |
I've been extremely pleased with the sound using either a single-ended tuner or a balanced D/A converter. Erik
Would a woodchuck bother to chuck MDF? |
#5 | |
Account Disabled
I have thought that two sources, however, could provide us with more convenient advanture for gain adjustment, if wanted. Happy New Year! |
#6 | |
The one and only
adjustment with only one pot. You might consider something like it. |
#7 | ||
So here it is, the BoSoZ with one CCS. A few notes about this circuit. I set R75 = 7.5 and R77 = 100K, so that the value of the Iconst = 80mA (trial and error in simm). Why I pick this number? Cause it is a standard resistor value. I could set the R77 = 15K but then, the R77 has to be 8.375 ohms (non-standard value) in order for Iconst to be 80mA. Is 100K for R77 too big? Is it ok to set it to 100K? :confsed: I leave the Z3 and Z4 attached for future use if I have a balanced source. I also use -60Vdc because I plan to use just one transformers (+55V and -55V tap transformer) Quote:
Another improvement?? :scratch
#8 |
The simm result (one CCS)
#9 |
Oooh, again....
Need comments. Especially the value of R77 (100K). Thx!
#10 |
The only thing to remember is that any resistance between the sources of the differential pair will mess up the symmetry of the outputs. You could get rid of the resistors completely, but then you have to find a way to get rid of all the extra gain. Kind of a catch 22 situation, unless you use feedback (which could be cool, because you could apply susy to the circuit).
Nobody |
| 100watt power, fixed gain far cleaner than Marshall amp any sugestion | opik | Tubes / Valves | 6 | 19th January 2007 11:35 AM |
| Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? | promitheus | Pass Labs | 87 | 19th February 2006 03:15 PM |
| Need a book sugestion | tpenguin | Solid State | 18 | 11th May 2004 01:57 PM |
| X-bosoz vs. CCS X-bosoz, how does the sound compare? | acliao | Pass Labs | 14 | 26th February 2004 12:55 AM |
| Page generated in 0.12966 seconds (70.90% PHP - 29.10% MySQL) with 11 queries |
