Old 13th April 2014, 11:37 PM   #1
j beede is offline j beede  United States
Default Amp is great... power switch not so much
It's been 7 years since the power switch in my Threshold 400A "exploded". This morning the switch in my Stasis 3 failed. Not fun.
The last time I lucked out and found a Panasonic replacement at HSC Surplus. Sadly that store is long gone. Anyone know of a source for a JC1-A8-BB-A? My search shows that this topic comes up now and again... but I see no evidence of anyone actually acquiring one. Ideas?
Old 14th April 2014, 01:30 AM   #2
Andersonix's Avatar
There's still Halted (HSC Electronic Supply) in Sunnyvale:
HSC Electronic Supply - Silicon Valley's Electronic Marketplace
Old Yesterday, 04:08 PM   #3
ticktock's Avatar
Due to age this isn't that extraordinary.
Consider retrofitting a soft start circuit.
thank you papa !!
Blaue Leuchtdioden machen blöd. (hb)
quod licet iovi, non licet bovi
Old Yesterday, 07:32 PM   #4
Agreed, not extraordinary. The data sheet for this breaker/switch specifies MTBF as 6,000(!) operations under bias. That's an average of about one cycle every two days for an amp of this age. Unfortunately, their estimate was about spot on.
If I can find a rocker switch that fits the same cutout I will go that route. An internal 10A slow blow fuse (like most amps) in series with the switch should preserve the amp's stock appearance and improve the tactile feel of the switch over the dreaded "springy" feel of the stock unit. In twenty years of use covering three Threshold amps I have had two failed breakers and zero circuit breaking events. Knock on wood.
Looking for 6/12 amp rotary power switch, Phase 700B amp PacificStereo Parts 12 30th October 2011 12:11 PM
Sansui Au-9500 power transformer and heatsinks great for DIY Amp athos56 Swap Meet 1 6th July 2011 10:26 PM
Power switch for B&O 1000asp. lazenna Solid State 1 7th January 2009 04:42 AM
Adding a 12V power trigger switch to Electrocompaniet Power Amp maxzimum Solid State 0 11th April 2008 01:54 PM
PV CS800 clip LED's & power switch don't light javey Solid State 2 3rd May 2005 02:31 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
