Amp for Thiel cs5 - diyAudio
Old 12th April 2014, 12:36 AM   #1
Default Amp for Thiel cs5
Well I'm looking for a used amp or monoblocks to run a current hungry speaker
The Thiel cs5
Drops down to 2 ohms at 40 hz
Old 12th April 2014, 02:09 AM   #2
The one and only
Nelson Pass's Avatar
Aleph 0 loved that load.
Lacking that, you build a simple push-pull follower Fet with lots of outputs and
heat sinks and power supply and bias the crap out of it.
Old 12th April 2014, 02:14 AM   #3
What about the Os? And could I bridge it later on?
Maybe up grade to two.
Thank you Mr Pass
Old 12th April 2014, 02:27 PM   #4
The one and only
Os not so much. The charm of the 0 was that you could overlay the thd
vs power curves for 8, 4 or 2 ohms and get the same curve up to clipping.
It was developed around Thiel 3.6's.
Old 12th April 2014, 08:24 PM   #5
That's awesome!!!!!
Old 13th April 2014, 09:59 PM   #6
Well if you get any trade-ins let me know.
I'm ready to buy👍
Old 26th April 2014, 11:38 PM   #7
Got the aleph 0 :-D
One issue tho one amp only works in balanced?
Any clue? Switch maybe?
Old 26th April 2014, 11:59 PM   #8
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
U formed shortie plug , pushed in 1 & 3 holes in XLR
or decent quality XLR jack , with soldered bridge wire between pins 1 & 3
then RCA input will work
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 27th April 2014, 01:30 AM   #9
Thanks Zen!
I'll try that in the morning.
If it works does that mean I need a new switch???
Old 27th April 2014, 09:20 AM   #10
Zen Mod's Avatar
for my knowledge , Aleph 0 doesn't have that switch
I made a mistake in previous post , assuming that Aleph is having both RCA and XLR input connectors ; in fact , amp is having just XLRs , so all you need to feed it properly from unbalanced source is to make RCA-XLR interconnect , with XLR pins 1 and 3 joined/shorted
Thiel CS3.6 Crossovers; Tonearm Headshells & Rega Belts & Capacitors dtm1962 Swap Meet 2 26th February 2013 04:36 AM
Yamaha CS5 mono synth Gezz Instruments and Amps 0 9th July 2007 11:51 PM
Thiel & Partner (Accuton) C11 Tweeter Yunick Swap Meet 0 25th October 2006 06:58 PM
Measurement & info about Thiel & Partner's new and round C-82 EngelholmAudio Multi-Way 0 27th September 2002 04:26 PM
Is my KEF CS5 crossover faulty? paulot Multi-Way 9 28th November 2001 02:32 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
