2sk246 bias problem - diyAudio
Old 11th April 2014, 10:52 AM   #1
Default 2sk246 bias problem
Hi
I use the pair 3sj103&2sk246 in the F5:
When I tray to bias , the 2sj103 bios normally, when I clock count the pot the current rise.
But when I try to bias the 2sk246 the max is 0.2A when the 2sj103 gives 1A.
I have many of this transistor and after replace the results is same.
thanks
Old 11th April 2014, 11:01 AM   #2
Soundhappy's Avatar
bios ?
do you want talk about bias ?
class A amplifiers with full range speakers
sings like angels in heaven
Old 11th April 2014, 12:17 PM   #3
The Dastardly Dad of Three
It's best you approach these thing systematically.
Use the same dc supply voltage as shown in the f5 article.
Then measure important voltages eg Vgs etc and put them on this thread.
Others who take picture and use schematics with measured voltages written on the diagram tend to get quite a lot of help.
Old 11th April 2014, 12:38 PM   #4
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
it seems as matter of Jfet Idss
so , schematic please , so we know what to write
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 11th April 2014, 12:52 PM   #5
hi
i remove the protaction transistor and r17,19,15.
Old 11th April 2014, 01:30 PM   #6
Zen Mod's Avatar
set both P1 and P2 to zero - confirm same measuring ZERO OHMS across R5 and R6
change R5 and R6 to 4K7
start biasing procedure - plenty of tutorials ( member 6L6 and others ) around
Old 11th April 2014, 01:36 PM   #7
thanks. i change the R5,R6 to 4K7.
Old 11th April 2014, 01:48 PM   #8
Zen Mod's Avatar
what ?
you will change ........ or you already change , prior to starting this thread ?
Old 11th April 2014, 01:57 PM   #9
no i will change and post the results.
sorry for my bed English
Old 11th April 2014, 02:24 PM   #10
KatieandDad's Avatar
You are completely changing the whole set up of the circuit.
Selling Toshiba Transistors - 2SJ74V, 2SK170BL, 2SK246, 2SJ103, 2SA970, 2SC2240 Ruach Swap Meet 37 18th May 2017 04:48 AM
Idss matched 2SK246 Y NYCOne Swap Meet 0 26th July 2011 10:03 PM
Bias problem- 1 Socket shows extremely low bias! otokomae Tubes / Valves 12 31st December 2008 10:01 PM
2N series Fets like 2SK246/ 2SJ103 ? ashok Solid State 8 3rd June 2008 10:06 AM
Wml Bias Problem malan Solid State 0 25th January 2005 02:50 PM
Copyright 1999-2017 diyAudio
