Rotary front panel power switch for 4U chassis - diyAudio
Old 7th April 2014, 07:33 PM   #1
Default Rotary front panel power switch for 4U chassis
Haven't had any luck finding a good solution here, so thought I'd ask...
I'd like to add a front panel power switch (rotary 2 position) to my pending F4 amp build
That said, I haven't found any switches yet with a barrel length long enough to handle the 4U chassis's 10mm+ front panel thickness. All mains rated rotary switches I have found support a +/- 5mm max panel thickness.
Any recommendations?
thanks
bryan
Old 7th April 2014, 08:33 PM   #2
Think about milling the panel in the area in which you want to place the switch
Old 7th April 2014, 08:51 PM   #3
already have a note into a friend with a vertical mill
hoping that perhaps there is a part/ solution out there I just haven't found yet
bryan
Old 7th April 2014, 09:10 PM   #4
Danger Mouse's Avatar
maybe with a trick.
Take a lorlin rotary Switch. From the datasheet they could handle 250V at 0,15A.
And switch with that Relais, which could handle your mains voltage at the Relais-coil
The Relais (rated at XXX Ampere) then switch your mains.
I thought about to try a similar Setup to Switch on 2 amps.
Because powerswitch is only rated 5A at 250V and i want more for reliabilty.
Any suggestions if this could work save?
I think it should, but i`m not sure
Old 7th April 2014, 10:07 PM   #5
grimberg's Avatar
Originally Posted by bjorgens View Post
...hoping that perhaps there is a part/ solution out there I just haven't found yet
bryan
Look for a potentiometer shaft extender. Contact Steve at Apex Jr. (Apex Jr.Home Page) and ask him if he has one available.
Old 8th April 2014, 02:47 AM   #6
Thanks folks... Spoke to my buddy with a vertical mill, and he's willing to trade machine time for conversation and beer, so that's the plan for now.
Cheers!
Bryan
Power ON/OFF - Rotary Switch derik736 Parts 6 1st February 2014 06:50 AM
5A-250v rotary power switch? muresan_c_dan Parts 2 18th July 2013 09:13 PM
4U deluxe chassis bk856er The diyAudio Store 1 1st December 2012 08:02 AM
4U chassis thor61 The diyAudio Store 1 20th November 2012 12:17 AM
Push button power On/Off switch for a 10 mm front panel NicMac Parts 7 22nd February 2010 08:24 PM
Copyright 1999-2017 diyAudio
