Some questions on an Adcom 5400 - diyAudio
Old 6th April 2014, 11:19 AM   #1
beanbag is offline beanbag  United States
Default Some questions on an Adcom 5400
Hello,
I hope this is the right forum to ask these question.
I recently got myself a used Adcom GFA 5400. It is the Version 1 made in Japan. As compared to my other Adcom 535L, it seems that the higher notes that a cello plays have kind of a nasally, harsh, scratchy, annoying sound. The highs sound a little bit more forward and harsh, vs the 535L sounds more smooth or laid back. These differences seem small to me, and I am not even sure they exist. So a couple of questions:
1) I read about the main difference btw bipolar and MOSFET amps is their distortion characteristics. What would be the most useful test for me to measure on the 5400 to see this (or rather, to differentiate its sound from the 535L)?
2) I would be willing to change out the caps or make a few other tweaks if I am pretty sure they would make a difference. So for example:
a) the power supply caps don't really look bulged, but the top are convex by about 1/16" of an inch. Worth changing out?
b) Any other caps worth changing out?
And what kind of measurement to make to confirm that these changes made a difference?
3) I would also like to cut down the gain by about 10 dB since I am driving it with a DAC directly. Where would be a good place to do it?
4) I read another thread where some guy kept increasing the bias to ridiculous levels, and claimed the sound kept getting better and better. Now the service manual says 35mV over .56 ohms, or 63mA. I briefly increased it to 180mA, but didn't really notice a big difference. I didn't want to toast the amp or anything. Is this worth doing?
I don't know if I am allowed, but I can post a schematic if requested.
Old 13th April 2014, 06:32 PM   #2
Andersonix's Avatar
Short version why 5400 doesn't live up to its potential:
3 pairs of output transistors and source resistors not matched well enough.
PS too small w too much ripple.
HS too small for glorious amounts of bias.
Old 18th April 2014, 06:18 AM   #3
I should read more articles about the Pass or MOSFET designs, but what is it about them that they need high bias to sound good? Or rather, that higher bias makes them sound better. If it's because it reduces the distortion, then why not design in lower distortion or higher feedback in the first place?
Old 18th April 2014, 11:36 AM   #4
flg is offline flg  United States
flg's Avatar
Yes, reading more of Pass will answer these questions. Even the classic Zen series of amp articles probably covers this subject well.
Basically, you can't just "design in" lower distortion. You do the best you can, with the devices that are available, at balancing all the necessary parameters to acheive the design goals. Most device parameters vary with variation of other parameters as can be seen in the curves on the datasheet. But, operating in a linear, low distortion manor is sometimes difficult. That might be graphed more as a strait line rather than a curve. You can see from some curves in the datasheet that as current goes up, the curve becomes more of a strait line.
Feedback is another touchy issue with some. Many think that although feedback lowers the measured THD numbers, the actuall residual distortion products of a high feedback circuit, although low, are more damaging to the sound than the simpler, lower order distorion of a circuit with much less or no feedback.
If you've been a member here for 10 years I would have thought you would have picked this up? You must of spent to much time in one of those other forum catagories. Passdiy and firstwatt www sites have many short papers and Zen articles that will get you up to speed on the Pass philosophy
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 18th April 2014, 11:40 AM   #5
flg's Avatar
Yep, that's most of it!
Old 18th April 2014, 05:01 PM   #6
Andersonix's Avatar
NP's 'Leaving Class A' article is a good summary.
Old 18th April 2014, 06:48 PM   #7
delecoy is offline delecoy  United States
delecoy's Avatar
I'm sure there are plenty here that know better than me, and would probably even call bs- but I could hear when the bias was out on my gfa-535 ( high or low ) and it was always most evident in the treble. The original pots were finicky to set, and constantly drifting. Replaced them to alleviate the problem. Anything outside +-25% of the recommended bias setting always had me opening it for a reset. Having read so many threads here on the relationship between bias and sound quality had me wanting to set it higher, but my ears were telling me otherwise with those amps. Perhaps the 5400 is behaving similarly.
Old 18th April 2014, 06:55 PM   #8
Andersonix's Avatar
GFA-535 is a BJT amp, so it has an 'optimum' bias point. But MOSFET amps like the GFA-5400 sound better and better (lower distortion) with more bias.
Old 16th July 2014, 12:14 AM   #9
Andersonix's Avatar
Here's the schematic for the L channel of the 5400:
Old 3rd August 2014, 10:12 PM   #10
Rnickl is online now Rnickl  United States
Not sure how much it adds to the thread but, I recently picked up a 5400 with some bad caps in the PSU. I was able to clean off the board good enough and Andersonix was nice enough to lend me some caps for a temp fix, I had to piggyback some smaller value caps but it works. Pictures below of the PSU board, bad caps and temp fix. I pulled one cap apart and it was near bone dry, only a few drops of electrolyte left inside the case.
I have 110VAC mains and re-tapped the transformer for 220VAC to lower the rail voltage. Now that I know I still have plenty of power at the lower voltage I should be able to recap with larger value caps on the stock PSU board.
A75 and adcom gfa-5400 ctong Pass Labs 94 19th April 2015 12:03 AM
Adcom gfa-5400 mods? orbanator7577 Solid State 18 28th June 2013 02:49 PM
Adcom 5400 schematic needed ctong Solid State 1 4th June 2013 07:25 PM
Adcom GFA-5400 kenscott30 Swap Meet 0 4th December 2005 05:08 AM
Adcom 5400 Power Amp Distortion - Need Help partialresponse Solid State 4 29th August 2005 03:26 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
