Old 5th January 2004, 04:49 PM   #1
Question Aleph 2 speaker protector?
In the original NP design, Aleph 2 only used Inrush Current Thermistor. That's why I saw many DIYers adding either Speaker Protector circuit or Delay-relay mechanism to protect their speakers. Is this really necessary or NP's original design is good enogh!
Can any one share your thought?
Example are here:
http://myweb.hinet.net/home4/chihc/a.../control-2.jpg
He has both delay-relay and speaker protector boards.
Thomas
Old 5th January 2004, 06:07 PM   #2
diyAudio Moderator Emeritus
roddyama's Avatar
There were a few that I've seen that have tried, or have implemented a relay disconnect of the speakers. Most however were talking about implementing a delayed power-up with a soft-start circuit to limit the high current inrush during power-up.
Rodd Yamashita
Old 5th January 2004, 08:11 PM   #3
Yonnat is offline Yonnat  France
Send a message via ICQ to Yonnat
I ask for the same question a few month ago, Mr Pass himself said that he never heard any problem with Aleph amps who destroyed speakers, so I used the original scheme and it works perfect, it is sure that your work must be perfect soldering, isolating and so on.
Yonnat.
Old 5th January 2004, 11:54 PM   #4
Send a message via AIM to jewilson
Just finished an Aleph 1.2 and there no turn on thump on pops wit these amps.
Jim W.
Old 6th January 2004, 12:57 AM   #5
Don't fuse the rails. You'll regret it.
Grey
Old 8th January 2004, 02:38 AM   #6
Hi! Grey how about fuse in between transformer and the brigde rectifier? Is this O.K.
Old 8th January 2004, 03:40 AM   #7
You don't want to put a fuse their. The Fuse goes on the AC line so when it goes everthing goes off. By fusing the the bridge you would still leave the tranformer running and part of the supply that was not fused. That could cause a cascading failure. Put the fuse on the AC side before the transformer.
Jim W.
Old 8th January 2004, 03:47 PM   #8
Default Another example.
This is another case used by one DIYer in Taiwan in his Aleph 1.2. The circuit use one switch to protect the power, bypass the thermistor after 7 sec. and switch on the speaker after that. The good thing is if the power is off, the relay shuts off right away. The original design also comes from diyaudio here:
Pulse Power Switch
How about sharing your idea regarding this design?
Old 8th January 2004, 04:54 PM   #9
I don't think any of this circuits is needed.
There sure is some turn on pop in the speakers,but even when used with very sensitive drivers like Lowther or Fostex it doesn't hurt.
bARTEK
Old 8th January 2004, 08:53 PM   #10
Totally unnecessary and over complex
I don't know of any standard transformers that offer 16VAC with the 50 or 40 VAC needed for an Aleph. That’s a custom transformer
Why would some on build this circuit with all the relays, this is a poor design........
Jim W.
DC protector ?? ping_31140 Pass Labs 9 18th January 2009 09:34 AM
Loudspeaker Protector muzza Solid State 49 29th April 2008 03:13 PM
Speaker Protector With MOSFET IrishboyM4 Solid State 2 23rd April 2007 10:49 PM
Speaker protector gaminn Parts 0 9th April 2006 04:43 PM
What is a peripheral protector?? CryingDragon Solid State 8 13th September 2002 08:37 AM
Page generated in 0.13793 seconds (66.89% PHP - 33.11% MySQL) with 11 queries
