Old 5th January 2004, 01:38 PM   #1
volle is offline volle  France
Question A problem in my diy Zen
Hello I'm a new "Zendiy". I hope I will show you my realization soon...
I meet a problem maybe someone met too.
During the test of the two channels, I replaced the 50v unregulated by a power supply and the two worked very well. When I tryed with the 2x18v transformer, I have a problem on a channel I can't explain. R4 has no action on the circuit. The voltage across R0/R1 is about 0,75v and I can't adjust it. I havn't this problem on the other channel. Q4 seems to work well and I can observ all the voltage showed on the schematic (no exactly the same value due to R4).
I don't understand what could be the cause of this behavior. Moreover there are no difference between the two channel circuits.
Thanks for your help and happy new year
Vianney
Old 6th January 2004, 03:07 AM   #2
Which version of Zen are you referring to?
Thomas
Old 6th January 2004, 08:20 AM   #3
Hoops!
It's the Penultimate Zen (Part4).
Thanks.
Old 6th January 2004, 07:00 PM   #4
joensd is offline joensd  Germany
Do you have about 22V at the drain of Q1?
Are you sure the pot´s ok?
Pop another one in if you have one spare or better measure it.
Cheers
Jens
Old 6th January 2004, 07:19 PM   #5
Do this one step at a time. What I will do first:
1. Make sure the 2X18V is in series, not parallel.
2. Check to see if the output after the bridge rectifier and the 25000uf cap is +50V.
Once this is certain, then you can check the rest of your main board.
Thomas
Old 8th January 2004, 03:21 PM   #6
I tested my board as you said. The pot is still ok.
I can observ about 47V after the cap (I have only 22000uf) ; and 40v at the source of Q5.
On the " good " channel, I have 26,8v at the drain of Q1 when there is 0,66v across R0 and R1.
As N.Pass said : " Adjust R0 so that the drain voltage of Q1 is 1/2 the regulated voltage plus about 2 volts ".Thus I need 22V. So I will adjust R0… as soon as possible.
On the channel wich doesn’t work , I check the drain of Q1.
Effectively there is a problem, I have 3,3v whatever R4…. I see about 4v between the gate and the source of Q2 but 0V between the gate and the source of Q1.
Thanks for your help.
Vianney
Old 9th January 2004, 06:34 PM   #7
If you have both resistors R0&R1 installed and measure 0.75V you should have a bias of 2.3A which doesn´t sound too bad so far.
The drain of Q1 is a big problem. Of course the whole bias circuitry doesn´t work then.
My first guess would be you touched the mosfet in a kind of loaded moment and it has gone to semiconductor heaven.
Did you measure the mosfet?
It probably has a short.
You can use this article to test the mosfet or your multimeter.
If this is not the case you probably have a short in your wiring somewhere but I don´t think so.
Good luck
Cheers
Jens
mtx amp problem [[help!!]] fuzzypinkhat45 Car Audio 3 8th July 2008 05:34 AM
CDM 2/29 Problem – HELP! Bassivus Digital Source 29 23rd December 2007 10:00 AM
FRD/ZMA Problem Twisted85 Multi-Way 5 4th December 2006 01:19 PM
p3a problem MaXiZ Solid State 17 16th July 2005 07:14 AM
Page generated in 0.20303 seconds (35.86% PHP - 64.14% MySQL) with 10 queries
