F5T Mosfet options - diyAudio
Old 25th March 2014, 07:07 PM   #1
bikerbub's Avatar
Default F5T Mosfet options
I've been reading up on the F5T for a few weeks now, hunting around the forums and finding most of the answers I've needed. The one thing that keeps tripping me up is the output Mosfets, because the original Fairchild components specced by Mr. Pass are only available in bulk from suppliers such as Rochester and Harry Krantz.
I saw the FQA36P15 and FQA28N15 mentioned on a thread from a few years back with very little follow-up. They are slightly different from the FQA16N25 and FQA12P20, with lower Vdss and higher Id. They also have a significantly higher typical Crss of 110pF, which Fairchild still considers to be "low."
I'm wondering if anyone has had the opportunity to compare these devices with a curve tracer to see if they exhibit similar characteristics, as they are much easier to come by than their Pass-approved equivalents. If not, what are the current alternatives being used? I've heard of Toshiba parts with lower Id being used, but I'm not familiar with their model numbers or characteristics in comparison.
Thanks,
Josh
(Originally posted this in the SS section by mistake)
Old 25th March 2014, 08:08 PM   #2
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Have your look at the Mouser and Dig-key web sites?
FQA36P15 Fairchild Semiconductor | Mouser
FQA28N15 Fairchild Semiconductor | Mouser
FQA16N25 Fairchild Semiconductor | Mouser Obsolete
FQA12P20 Fairchild Semiconductor | Mouser Obsolete
I build, therefore I am.
Old 25th March 2014, 10:29 PM   #3
bikerbub's Avatar
Yes I took a brief look at the datasheets, and the curves are not quite the same, but I'm just wondering if anyone's used them with any sort of success, or deemed them too different to work without major rework of the schematic.
Old 25th March 2014, 11:51 PM   #4
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
is there a problem obtaining IRFP in USA ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 26th March 2014, 01:04 AM   #5
nigelwright7557's Avatar
I wouldn't worry too much about curves.
Feedback takes care of any none linearities.
I have used irfp240/9240 which are quite different devices with some success.
Old 26th March 2014, 11:18 AM   #6
gk7 is offline gk7
Probably not a problem obtaining them but a problem with the P-channel defect:
Old 26th March 2014, 11:27 AM   #7
Zen Mod's Avatar
besides being blind , I'm also deaf , so I'm not finding that as defect
Old 26th March 2014, 11:43 AM   #8
flg is offline flg  United States
flg's Avatar
To be clear, IRFP does not have any "Defect". The "P" in IRFP stands for plastic as in TO-3P.
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 26th March 2014, 12:14 PM   #9
BobEllis's Avatar
I remember NP mentioning that the IR version of the IRFP9240 had a glitch in its transfer function that was audible, but not so bad and the parts are usable. These are the parts that are currently available. Fairchild's version of the same part did not have that glitch. I am running out of my stock of the original Fairchild parts, but that means I am building amps.
Old 26th March 2014, 12:26 PM   #10
Yeah, Papa commented on it in the BA2 article, in the distortion vs frequency section:
Burning Amplifier BA-2
He also discussed it in the testing mosfet article I believe.
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
When does an F5T transition from Class A to A/B? dhenryp Pass Labs 4 7th November 2013 06:05 PM
novel heatsink for F5T gbullimore Pass Labs 19 5th December 2012 10:31 AM
My F5T V3 build buzzforb Pass Labs 91 27th October 2012 09:01 AM
Mosfet driver options Pozar Class D 10 22nd January 2008 03:02 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
