#11 |
Correct. All 12 fets (6 via source resistors) all connect together through the yellow wire in Dale's Aleph boards. I added a peice of 12 ga solid copper wire over the trace that connects the sources on one side to the drains on the other.
I was after a little more power, so I have 16 fets and .68 ohm source resistors to give around double the bias barring ang other component changes. I also installed a pot for r19 to adjust the bias. |
#12 | |
Can you elaborate a little bit about this? I thought the CLC is always the better way to reduce the AC ripples! Thomas |
#13 |
But it's hard for a choke to dissapate 50 watts and not self destruct. They had a little over 2 ohms resistance and 5A flowing through.
I've been toying with the idea of using a source follower Zener diode regulator like the zen preamps(I don't remeber which one). but since the amps pull a constant current, the resistor will do for now. I Know I'm a dumb *** some times. I thought that since they were air cores, they couldn't saturate. But I forgot to consider the ESR would mean 10v drop at 5A. |
#14 |
Brian, what ga inductors did you use ? I plan on using Solen 14ga inductors.
left lane is for passing, slower traffic keep right please. |
#15 |
Thanks!Brian I think I understand it now.
#16 |
I Think they were 16 ga. I remeber thinking "yea, 16 ga can carry 6 amps, no problem. The problem is 100' if 16 ga rolled up so there is no surface area exposed to the air for cooling. I would guess that you need to see less than .75 ohms or so to keep the temp down in the core. I also would not recomend home wound units because the layers are not rolled tight enough to cunduct the heat from the middle layers to the surface. Or maybe pot them in some thermally conductive epoxy to a heat sink?
| L/R Boards and Matched IRFP240 Boards for Aleph/ A-X | lgreen | Swap Meet | 7 | 25th August 2009 04:56 AM |
| FS: Aleph 30 kit / 4 Heatinks 6x6x3 | Bengali | Swap Meet | 7 | 3rd June 2009 09:02 PM |
| Pass Aleph 1.7 boards, Zhaolu 2.5A, P700 VRDS, UGS PS boards, dac chips | analog_sa | Swap Meet | 4 | 14th March 2009 05:29 PM |
| WTB: Aleph Output boards/Aleph-X | rchua77 | Swap Meet | 0 | 31st March 2008 04:56 AM |
| Can I use Brian GT's Aleph boards for a Aleph 1.2 | raincheck | Pass Labs | 2 | 27th May 2002 02:21 PM |
| Page generated in 0.10064 seconds (65.19% PHP - 34.81% MySQL) with 11 queries |
