Need DigiKey PN for 9610 heatinks for Aleph 2 boards Need DigiKey PN for 9610 heatinks for Aleph 2 boards - diyAudio
Old 4th January 2004, 08:21 PM   #1
Jean is offline Jean  United States
Jean's Avatar
Send a message via AIM to Jean
Default Need DigiKey PN for 9610 heatinks for Aleph 2 boards
I just read many threads and couldn't find what I needed. I am looking for heatsinks that I can order from Digikey (thats where I am ordering my irfp9610s and zeners from) that will fit BrianGT aleph 2 boards.
Thanks !
left lane is for passing, slower traffic keep right please.
Old 4th January 2004, 08:35 PM   #2
Jean's Avatar
Will vertical mount 294-1034-nd or 294-1024-nd fit ? Trying to locate something that will fit right in on the board w/o getting in the way of other components.
Old 4th January 2004, 10:35 PM   #3
BDP is offline BDP  United States
I believe the digi-key number that would work is HS107. My voltage rails were -\+ 33 volts. As you can see the differential pair didnt need heatsinks.
BDP
Old 4th January 2004, 10:48 PM   #4
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
i don't use heatsinks for the 9610's on my Aleph 2 at all...
guess it just depends what you are comfortable with.
Old 4th January 2004, 10:50 PM   #5
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
None of those transistors need heatsinks but you may get better performance if the diff pair is thermally coupled on the same heatsink.
Old 4th January 2004, 11:08 PM   #6
Jean's Avatar
I went ahead and ordered 20+ small heatsinks from digikey, maybe a few will match and fit good on the board.
Thanks!
Old 5th January 2004, 01:55 AM   #7
Brian Donaldson is offline Brian Donaldson  United States
Brian Donaldson's Avatar
I used a peice of L extrusion to connect diff pair. Small whatever for ccs from surplus shop
The chokes started to stink. They were replaced with big 2 ohm resisters.
Old 5th January 2004, 02:19 AM   #8
nbaula is offline nbaula
HI! Brian I see that you did a good job doing the point to point connection of the CCS and the output FETS. How did you connect the CCS and the output FETS ( Source of the CCS to the Drain of the output FETS ). Thank you for your'e input .
Old 5th January 2004, 02:37 AM   #9
They connect on the board through the 12 ga yellow wires.
Here's a better pic of point to point with the turret terminals Mark Gulbranson ( I hope i didn't butcher his last name too badly) used on his Aleph 2
OOps, That was the wrong pic. Here I'm swapping blown fets. They are sooooo sensitive to static without the rest of the circiut.
Old 5th January 2004, 03:16 AM   #10
H! Brain is you're driver board from Dale's group buy, if so please help me understand. Refering to Kristijan site (http://web.vip.hr/pcb-design.vip/) there are six FET output and CCS , The CCS FET ( source is connected to a one ohm resistor )to the output FET( Drain). These connection is only connected by that yellow wire am i right?
Need DigiKey PN for 9610 heatinks for Aleph 2 boardsHide this!Advertise here!
L/R Boards and Matched IRFP240 Boards for Aleph/ A-X lgreen Swap Meet 7 25th August 2009 04:56 AM
FS: Aleph 30 kit / 4 Heatinks 6x6x3 Bengali Swap Meet 7 3rd June 2009 09:02 PM
Pass Aleph 1.7 boards, Zhaolu 2.5A, P700 VRDS, UGS PS boards, dac chips analog_sa Swap Meet 4 14th March 2009 05:29 PM
WTB: Aleph Output boards/Aleph-X rchua77 Swap Meet 0 31st March 2008 04:56 AM
Can I use Brian GT's Aleph boards for a Aleph 1.2 raincheck Pass Labs 2 27th May 2002 02:21 PM
Copyright ©1999-2017 diyAudio
