CRC Filter resistors - diyAudio
Old 24th March 2014, 05:22 PM   #1
alibear is offline alibear  United Kingdom
alibear's Avatar
Default CRC Filter resistors
Hi all, could you please tell me the reason why the resistance in a CRC supply is usually made by putting resistors in parallel and not just using one resistor. The Pass type of supply seems to use 4 x 0.47 ohm. Could this be substituted for a 0.1ohm of a higher wattage, or are there other reasons why parallel resistors are better.
Thanks for your help
Alan
Old 24th March 2014, 05:33 PM   #2
The one and only
Nelson Pass's Avatar
Yes, you can use a single resistor of higher, it's just a matter of watts. The
parallel resistors are just handy and usually cheaper.
Old 24th March 2014, 05:35 PM   #3
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
-wattage
-stock
-temperature spread
just few reasons
edit - Pa was faster
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 24th March 2014, 06:05 PM   #4
Triodethom's Avatar
I see time at the beach did well by you.
Old 24th March 2014, 06:27 PM   #5
alibear's Avatar
Thanks for your replies, much appreciated. Forgive me for being so stupid, I have been doing some calculations regarding the wattage of the resistor and I have as follows:
1.5 amp current draw ( bias current ) through a 0.1 ohm resistor gives a volts drop of 0.15V and a power dissipation of 0.225W Where have I gone wrong please?
Alan
Old 24th March 2014, 06:40 PM   #6
and if this is a push-pull amp driving 2ohm you have a peak current of 12A. Thats a voltage drop of 1.2V, wich means 14.4W. And then there is charging of the caps.
Old 24th March 2014, 07:55 PM   #7
alibear's Avatar
Thanks for the help, I now understand
Alan
Old 25th March 2014, 12:45 AM   #8
ZUM911 is offline ZUM911  Australia
Follow on from this, can you use an umbilical lead as the resistance in the CRC? I plan to build a power supply in a separate enclosure to power my growing stable of FW clones and I'm thinking that a lead of about a meter or so from the power supply to the amp. I will have capacitor banks in both enclosures.
Old 25th March 2014, 01:44 AM   #9
Zen Mod's Avatar
yup
Old 25th March 2014, 11:48 AM   #10
yup
Just watch the AVERAGE current, because that is where the main heating (softened insulation) of the umbilical will come from. P=IČR
regards Andrew T.
Sent from my desktop computer using a keyboard
smd CRC filter Nikitas Power Supplies 12 23rd May 2013 06:12 PM
Indcutor in CRC filter of PSU frags Pass Labs 3 4th October 2010 04:56 PM
CRC Filter ? kacernator Tubes / Valves 2 31st July 2009 11:15 AM
crc pi filter tenderland Power Supplies 3 3rd January 2007 07:50 AM
Formula for CRC Filter Rarkov Parts 7 21st January 2004 09:22 PM
Copyright ©1999-2017 diyAudio
