Article - Sony VFETs part 1 - Page 74 - diyAudio
Old 25th August 2014, 03:22 PM   #731
WalterW is offline WalterW  Netherlands
oh no.....another precious VFET damaged
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6
Old 25th August 2014, 03:40 PM   #732
generg is offline generg  Germany
generg's Avatar
Juanitox,
The SK180 are all very different and having no feedback the gain difference between two unmatched can be big.
I have here accummulated around twenty SK180 and I am afraid there will be only three more or less fitting pairs....
But I implemented simply a very small source resistor of 0R1 in the path of the SIT with the higher gain and I got them fairly equal......
and the First Wtt is......a really First Class PSS Idea
Old 25th August 2014, 03:59 PM   #733
dady is offline dady  Balearic Islands
dady's Avatar
Send a message via MSN to dady Send a message via Skype™ to dady
OH OH OH, Meine kleine VFET you are conspiring with other women. Does came hot they?
Planning to sleep with SE with ccs or pushpull a la cyrclotron?
Esteban Bikić
Old 25th August 2014, 04:05 PM   #734
juanitox's Avatar
as i'm a little " brutus" i prefer to play with Vfet than i 'm used to do with tubes like AD1 or RS241 ...
cheap game here
French is not a crime.
Old 27th August 2014, 12:21 AM   #735
Botte is offline Botte  United States
Botte's Avatar
Listening update:
I have had a few friends over and they are amazed by the sound coming from the CSX1. It is so open and transparent and they can't get over how then can hear all the details in the sound. The amps have defiantly improved with some run time, becoming more open in the whole sound field. No talking heads in the middle, you are in the environment that the performance was recorded in.
As much as I love my F6, and it was better than the F5, I can say, I can't go back. I ordered another set of SITs and will make the F6 chassis into the common drain version when Nelson offers it to us. Bravo Nelson!
Old 27th August 2014, 12:59 AM   #736
Botte's Avatar
Originally Posted by Botte View Post
Listening update:
A little more context for my statement, I have 100dB speakers with a nice consistent 8 ohm impedance and don't need the damping offered by the F5 & F6. The SITs just make them sing!
Old 27th August 2014, 01:41 PM   #737
ci11 is offline ci11  United States
Very nice to hear that your CSX1 is making wonderful sounds. After my foray into some of the first modern implementations of 845 DHT amps 20 years ago, I learned that simplicity is always good! So a couple of questions: did you wind up using the LSK FE, and what sort of outcome would you estimate if the speaker were 4 Ohm and only 86dB sensitive?
I'm eagerly waiting for Part 2 (or Part n) as well so I don't have to change speakers....
Old 27th August 2014, 06:08 PM   #738
Botte's Avatar
I have not used the LSK folded cascode gain stage, just the regular CSX1 with the buffer on the input.
As for the lower sensitivity speakers, I think they would be fine if the impedance is even. You would most likely run out of power if you pushed them hard. I would think you would want something in the 90's at one watt for a better match. My two cents
Old 27th August 2014, 07:14 PM   #739
That's why I am hoping the "Part 2" article will come out soon so my speakers will be happy, and I will be happy.
Thanks!
Old 27th August 2014, 08:13 PM   #740
PKI is offline PKI  United States
PKI's Avatar
Crazy idea, but what if you plug the CSX1 into F4 for better speaker handling? Or, another words, can you scale down CSX1 so it works as a flea amp?
VFETs replacement, Sony TA-5650 pietres Solid State 2 7th October 2008 02:07 PM
vfets / transistors mojoat Swap Meet 2 4th January 2008 06:25 PM
I.S.O. Sony 50" plasma part mobyd Swap Meet 1 6th September 2006 08:17 AM
Copyright 1999-2017 diyAudio
