Article - Sony VFETs part 1
Old 22nd October 2017, 05:37 PM   #1361
luvdunhill is offline luvdunhill  United States
luvdunhill's Avatar
Originally Posted by Nelson Pass View Post
If you
can drive 500 ohms without significant distortion, you are doing fine.
Excellent, here are my results at 500 ohms
They are cute little guys
For maximum bandwidth you want buffers that have output impedances
lower than the DC values of the primaries. For the Jensen and Cinemag
examples, 25 ohm is desirable, although things don't fall apart until quite
a bit higher.
I need to think of a good way to test this on my bench.
Old 23rd October 2017, 09:04 PM   #1362
flg is offline flg  United States
flg's Avatar
I used to do quick and dirty method that would probably get you there. When you load the output with a value equal to the source Z, the output level will be cut in half(-6db). At 10k load, a 25 ohm output Z is relatively meaningless. But with 25 ohm load, 1/2 your voltage is dropped in the output Z and 1/2 on the load
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 10th November 2017, 07:34 PM   #1363
luvdunhill's Avatar
There is a nominal impedance for the transformer primaries, but that's for when
the secondaries are driving their rated impedance, which in these instances
they usually aren't.
With the 150:150:150:150 ohm line transformers we've been using as
autoformers, I have measured mid-band impedances of 5K or so. If you
a bit higher.
So, plugged them in and generated some smoke
In thinking about it, I have a few questions. Here is the schematic that elicited the smoke, I was using a balanced to SE XLR Adapter
1.) I am switching the buffer in and out of the circuit via a relay. I am just moving the input of the buffer, the output stays connected. Will this work? Is it better to switch the output, or must I switch both the input and out of the buffer?
2.) My buffer saw as load the primaries in parallel, which is pretty low and caused a resistor to smoke. This is much lower than the 500R above. This is because the negative input was connected to ground via the adapter. I am doing something wrong here, obviously. How can I fix it?
Thanks!
Old 10th November 2017, 08:25 PM   #1364
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Yes, you are doing something wrong.
The first step on the path to enlightenment.
I don't think you want the output of the buffer and the input signal
connected to the transformer at the same time. Also, always see to it
that the buffer input has something to look at, even if it's only a large
value resistor to ground.
Old 10th November 2017, 08:46 PM   #1365
luvdunhill's Avatar
The smoke was the first indication of that
Ok, so switch the output of the buffer. Makes sense!
It seems that I should also switch the input. Take this example:
I seem to loose the benefit of a balanced input, as I have the input resistor to ground? So, I guess if I wanted to have the buffer flexibility, I need switch it completely in/out, meaning both input and output?
In the case of the first diagram, where the switch toggles the buffer to be in-line, doesn’t the buffer still see 25R in parallel with 25R as load?
Old 10th November 2017, 11:00 PM   #1366
The one and only
You want the buffer to always have some DC connection to ground,
even if it's 1 Meg (or more likely 100K). Otherwise it might be led astray...
Old 11th November 2017, 01:03 AM   #1367
luvdunhill's Avatar
Thank you!
... and the second part of my question I believe is answered by “yes, the buffer has to drive a DC load of 25 in parallel with 25, as the primaries are in parallel.” My little buffer can’t do this.
I think the original question I meant to ask, was “when I am testing my buffer for low distortion, how can I approximate the load and/or use the transformer itself as an load approximation”. I misunderstood your answer of “500” to mean, stick a 500 ohm resistor on the output.
So, given my confusion, what would be the best way to bench test the buffer at a good approximately of the transformer load? Just use the transformer itself with the secondaries open?
Old 11th November 2017, 10:00 AM   #1368
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
you're always taking in account secondary load transferred to primary
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 11th November 2017, 05:21 PM   #1369
The one and only
Obviously the best way is to test it into the actual intended load.
That said, I find that a buffer capable of driving the "rated" impedance as a
resistance will do well enough into the transformer.
For example, the Jfet buffers I use won't drive 150 ohms, but are ok
into a 150 ohm tap on a transformer as long as the secondary system is
not driving its rated impedance.
I have a couple of amplifiers with 150:150:150:150 coils as autoformers
giving a gain of 12 dB into 10K ohm. They work fine driven by a pair of
2SK170/2SJ74.
Old 12th November 2017, 11:58 AM   #1370
dady is offline dady  Balearic Islands
dady's Avatar
Send a message via MSN to dady Article - Sony VFETs part 1
Hi Dear Mr. Pass, Since I built a sort of CSX1 but with balanced couple of Vfets and I am very comfortable with the dynamic of this topology with my speakers, I am interested in those transformers, where is possible to get them? Thanks in advance.
Best Regards
Esteban Bikić
Article - Sony VFETs part 1Hide this!Advertise here!
VFETs replacement, Sony TA-5650 pietres Solid State 2 7th October 2008 02:07 PM
vfets / transistors mojoat Swap Meet 2 4th January 2008 06:25 PM
I.S.O. Sony 50" plasma part mobyd Swap Meet 1 6th September 2006 08:17 AM
