F5 Toshiba Output bias Issue - Page 2 - diyAudio
Old 6th March 2014, 03:18 PM   #11
DGreen is offline DGreen  United States
Thanks for the responses and help. Will check out voltages this weekend.
Old 9th March 2014, 06:21 AM   #12
Success!! I thought a little more deeply about this build verses my previous F-5 build. I used the same type of board (CViller V-2-had an extra set). I compared the old boards with the new populated board and the components were all in order and matched the old board. The only difference on the new build were different output FETs and the use Artic Silver instead of silicone grease. I was pretty sloppy with the application of Artic Silver and when I pulled the FETs off of the heatsink to check there was a glob of the Artic that had squeezed out on the side of the FET and was in contact with the heatsink. Also, the Artic was on the screw that held the FET in place. I had checked for short between the drain and heatsink before I pulled off the FET and my meter didn't read a short. Hmm? I cleaned off the Artic Silver and used silicone grease and Alum oxide insulators and replaced the FETs, fired up one channel and the die of the FET measured 49 degress centigrade after about 1/2 hour or so. D/C offset 4 mV at .595V across R11 and 12.
I don't want to "diss" Artic Silver and it is not supposed to be electrically conductive, but I won't use it again for this type of application. Thanks guys for helping me with this. Greatly appreciated.
Old 9th March 2014, 06:50 AM   #13
The Dastardly Dad of Three
Excellent news - well done !
Old 24th August 2015, 08:50 PM   #14
I know this is an old thread, but it is worth noting that several Arctic Silver products are electrically conductive, although the company makes other greases which are not supposed to be. Which one did you use?
Also, how do you like the F5 with the Toshiba FETs in place? I am in the parts-gathering stage of my F5 build and am trying to decide between the usual IRF parts and these Toshibas on ~16V rails with 1A bias or so.
Old 24th August 2015, 09:20 PM   #15
The one and only
Nelson Pass's Avatar
If you have the Toshibas, I would use those. Very nice discontinued parts.
Weird F5 bias issue JZatopa Pass Labs 21 25th March 2015 03:36 PM
Re-Issue GB for F1 / F3 / F5 suds Group Buys 8 3rd December 2012 03:20 PM
Possible Bias issue?? JRGuitarGuy Instruments and Amps 20 9th November 2012 12:47 AM
Toshiba 2Sk3497/2SJ618 as outputs of the F5 NYCOne Pass Labs 8 7th July 2011 01:16 PM
f5 power up issue specialidiot Pass Labs 54 2nd May 2010 11:27 AM
Copyright 1999-2017 diyAudio
