Another Aleph J arriving - diyAudio
Old 23rd February 2014, 08:41 PM   #1
BobEllis's Avatar
Default Another Aleph J arriving
Feeling proud of myself for actually making progress. I got my ground bus bar (3" x 12" x 0.125") drilled out for the main cap connections and mounted the power transformers. I bought brackets to mount them vertically but since they fit (barely) laying flat that's the way to go.
I'd hoped to finish this amp today, but life has interfered, and I am waiting on a few parts. Resistors for the CRC, fuse holders for each transformer, and some hardware scheduled for delivery next Wednesday.
I can see that I am going to have to do the cap screw heat sink mounting mod - Otherwise I'll never get the front panel attached or be able to adjust the amps.
Nothing particularly special about the board setup, I used the store BOM other than using Fairchild IRFP240s and BC546C I had on hand. I bought the jfets a long time ago from ampslab and was pleasantly surprised to find at least 4 pairs with idss around 10 mA matched within .03 mA out of 20 pieces. I was also able to make 4 perfectly matched sets for my F5T.
There's not a lot of room to spare. Transformers are Antek 4220s. Smoothing caps are 68,000 F/50V. Chassis mount 25W 0R1 resistors will mount on the ground bus. I realize that's an "old school" power supply. Rectifiers and AC connections will be on the front panel.
Progress will be even slower for a month or two, as the surgeon says I can't lift more than 10 pounds after much needed back surgery. I may have to turn my daughter into my amp mechanic so I can listen to it during my recovery.
Old 23rd February 2014, 09:01 PM   #2
Marra is offline Marra  United Kingdom
And I thought mine was a tight fit.
Nice work Bob.
Old 23rd February 2014, 09:02 PM   #3
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
schweet
good luck with back surgery
I'm prolonging mine , now for more then 10 years now .....
in fact - not prolonging , still being in shape not exactly bad enough
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 23rd February 2014, 09:20 PM   #4
6L6 is offline 6L6  United States
6L6's Avatar
Tie all your grounds to one point on that gorgeous piece of copper. It should be silent.
Old 23rd February 2014, 09:33 PM   #5
Zen Mod's Avatar
even if I would split it in two - having full dual mono that way
Old 23rd February 2014, 09:34 PM   #6
BobEllis's Avatar
Thanks, guys.
ZM, I've put it off as long as I can stand. Actually I can't stand much, so it's time. I've managed to work the "No brain, no pain" theory to my advantage. Problem is I can't be on my feet for more than about 15 minutes or my legs go to sleep and I fall down. My personal doc/good friend is an avoid surgery if at all possible guy but has been pushing me to get it done for a couple years. Same guy did wonders for my neck, so I'm expecting good results.
I should be back making dodo posts in a week or so...
Old 23rd February 2014, 09:37 PM   #7
BobEllis's Avatar
I may split the ground busses with my F5T, I have the same caps and copper bar for it. We'll see how this one goes.
Old 23rd February 2014, 09:49 PM   #8
Zen Mod's Avatar
be sure to check in here , as soon you arrive home
Old 23rd February 2014, 10:15 PM   #9
NYCOne is offline NYCOne  United States
It looks great.
If you have the time/inclination, more photos are welcome.
Old 23rd February 2014, 10:50 PM   #10
BobEllis's Avatar
I'll post progress pictures when I start making progress again.
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 19 25th January 2014 03:15 AM
Russian triodes ГИ-15Б arriving in a few days tricomp Tubes / Valves 16 6th July 2012 07:55 PM
A mint Kenwood KA-907 amp is arriving, I need help/info/advice on restoring it. Kuja Solid State 5 22nd November 2011 12:46 AM
e-mail notifications not arriving every time halfgaar Forum Problems 7 17th May 2011 09:48 PM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 08:55 AM
Copyright 1999-2017 diyAudio
