Old 20th February 2014, 12:43 AM   #1
Default F5 Fuse burn after connect ground to chassis
Hi
I connect all the GND from the pcb's to ground through the cl-60 and everything is ok.
But when I connected to chassis (heatsink) the fuse burn
i check 10 time's if there is short between thw component and the chassis and there is no short
edit: i measure some ac volt between GND and chassis, no dc.
edit2: strange... even whan i turn off the transformer switch i still see the ac volt between GND and chassis !!
edit3: whan the transformer is off but i back the GND to chassis the ac down to 0v
I seems to me that the fuse burn on the start power when the gnd connect to chassis.
Old 20th February 2014, 05:10 AM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
pictures !
leave it out of mains until we solve this
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb ; Papatreasure
Old 20th February 2014, 05:29 AM   #3
Zen Mod's Avatar
measure resistance between main cable prongs and secondary
it must be infinite
Old 20th February 2014, 05:50 AM   #4
its INF
the amp work fine But only when the gnd in the "air".
edit: I try to start with one transformer each time(i have for each channel)
Old 20th February 2014, 06:22 AM   #5
two transformer
Old 20th February 2014, 06:39 AM   #6
Check the voltage from the heat sink to chassis before connect it. If you have voltage it is possible that one of the output transistors it is touching or making contact with the heat sink.
Old 20th February 2014, 06:43 AM   #7
hi tauro
i have ac volt when the amp is off between the chassis and the gnd.
when the gnd is on "air", the transistor not contact the chassis.
now i make soft start and torn on each transformer not Together and the amp is fine !!
Old 20th February 2014, 10:07 AM   #8
now r17,19 burn
Old 20th February 2014, 10:34 AM   #9
the ztx short, maybe the r17,19 burn because this transistor
Old 20th February 2014, 11:22 AM   #10
edit:
ok i think its the k170 that make the burn everithing
Should I directly connect my signal ground to chassis ground? Bricolo Solid State 4 18th March 2014 09:42 PM
TT signal ground v. chassis ground and hummmmmmm texaslonghorn Analogue Source 0 25th November 2009 02:30 AM
Chassis, ground, earth: connect? starbase218 Solid State 3 14th November 2007 08:56 AM
Chassis ground blows fuse krzanik Tubes / Valves 51 9th May 2007 07:29 PM
Chassis Ground = Circuit Ground --> Problems? rhildenbrand Pass Labs 5 23rd April 2004 01:08 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
